It is currently Sun Aug 17, 2025 6:19 pm
PostPosted: Thu Feb 04, 2010 7:32 am
Last Name: Thompson
Hi,
I about to close up my first every guitar (classical) this weekend so I have started to think about bindings. Im planning on using shellac finish (i.e. french polish) and im wondering if the shellac will adhere to plastic bindings? Are there any issues with using plastic bindings with shellac/fp finish?
I have a set of wood and plastic binding/purfling the plastic set is black binding, BW purfling with the wood set comprising of maple/BWB bindling and block patterned purfling. Im trying to work out which would look better on a Engelmann Spruce/EIR ?
If Shellac doesnt work with plastic the decision is out of my hands, if plastic is ok with shellac then Im unsure which to use.
Advice would be appreciated.
Anthony
PostPosted: Thu Feb 04, 2010 8:47 am
Shellac will adhere to plastic with no problems. It will impart a slight amber hue depending upon the color and grade of the shellac you use.
tim...
PostPosted: Thu Feb 04, 2010 9:54 am
Yep, shellac will stick to nearly anything.
PostPosted: Thu Feb 04, 2010 10:07 am
City: Lawrence
Zip/Postal Code: 66047
It's worked for me in the past
PostPosted: Thu Feb 04, 2010 4:35 pm
Last Name: Thompson
Excellent.
Anthony
