It is currently Sat Aug 16, 2025 2:44 am
PostPosted: Sun Jan 24, 2010 7:22 pm
First name: Arnie
State: Oregon
Zip/Postal Code: 97814
...and getting them a little too "done".
So now I know why they call it BLACK walnut.
gaah
PostPosted: Sun Jan 24, 2010 8:11 pm
Arnie, If you got some black spots, that is normal for walnut and it should scrape or sand off real easy.
PostPosted: Sun Jan 24, 2010 9:01 pm
First name: Arnie
State: Oregon
Thanks Mark. I probably won't be using the practice set for anything, but that's certainly good to know. [:Y:]
The second set of sides went much better. I think I had the pipe a little "warm" the first time. laughing6-hehe It was a practice set, and didn't have the curl that the second set had.
I'm not sure if this is "accepted" technique, but the burning seemed to be minimized as long as I did this:
As soon as I felt the wood start feeling pliable, I would take it off the pipe and hold the bend with both hands until it cooled down. I also modified the pipe to make an oblong shape instead of a perfectly round shape. All in all, a little better this time. ;)
PostPosted: Mon Jan 25, 2010 1:10 am
I just bent my first set and did close to the same thing. Once I had the piece bent to where I wanted it I would keep it warm and over bend it just a tad, took it off, blew on it to cool it down and it usually springed back to about where I wanted it.
Have any pics?
PostPosted: Mon Jan 25, 2010 8:03 am
First name: Arnie
State: Oregon
Luke wrote:
Have any pics?
I'll try and post some today. Do you want pics of the BBQ, or pics of the passable set? laughing6-hehe
PostPosted: Mon Jan 25, 2010 8:26 am
When useing a pipe, i put a damp rag between the pipe and wood and it seems to work alot better without the scorching problem.Just keep the rag spritzed while doing it.
PostPosted: Mon Jan 25, 2010 11:50 am
First name: Arnie
State: Oregon
Thanks Mark. Sounds sensible. I'll try that next time. [:Y:]
PostPosted: Mon Jan 25, 2010 5:29 pm
First name: Arnie
State: Oregon
Luke wrote:
Have any pics?
Here's my second attempt - all gussied up.
The first set, aka "Cajun Blackened Walnut", is in the background. :oops:
Edit to add: What a mess! But it's got the "lived in" look. laughing6-hehe
