It is currently Fri Aug 15, 2025 9:14 am
PostPosted: Wed Jan 20, 2010 5:07 pm
First name: Corky
Last Name: Long
City: Mount Kisco
I've bent sodes from silver (soft) maple, black walnut, Koa, and Pau Ferro, by hand, on a pipe heated by a torch. I've used foil to wrap the sides, and have wet them before bending. My experience has been that the difficulty of bending has gone in this order - (soft) maple, black walnut, Koa, and Pau Ferro, with the Pau Ferro being quite resistant to bending (although no problems with cracking.).
What am I in for with the Amazon Rosewood. It seems very hard and dense. Any guidance on technique, if at all different from the others? I do not have a Fox style bender. Still saving up for that tool. Thanks!!
PostPosted: Wed Jan 20, 2010 5:20 pm
Country: Romania
I will start soon one of these as well. My set is extremely hard and dense too so it will be thinned about 10-15% more than what I would do with average Indian/Madagascar. I don't think it will be more difficult than other rosewood. I bend on a pipe and gradually stopped using water all together. Probably in order to avoid breakage you could treat it like ebony. Press very closely to the tangent point using cauls. Free-handing at a distance induces too much leverage for brittle wood.
Build log
PostPosted: Wed Jan 20, 2010 5:43 pm
I bought a set of Amazon Rosewood last year but haven't got around to using it yet. The texture seems very similar to Brazilian Rosewood, which I normally bend on a hot pipe in pretty much the standard way: a bit of water sprayed on and just my gloved hands doing the pressing. I'd be interested to know what those who have had experience are saying. It's a pretty nice wood and with the recent crackdown on importing Brazilian Rosewood that we hear about, it may become the standard replacement! idunno
PostPosted: Wed Jan 20, 2010 6:10 pm
I have bent 2 sets so far. Easy to bend but with a bit of springback if left too thick.
I bend at .080" since its fairly dense and a bit thinner for the cutaway. Overall and easy wood to work with.
PostPosted: Wed Jan 20, 2010 8:02 pm
Bent a set last week at.088 with no problems at all.
In Markham,Virginia
PostPosted: Wed Jan 20, 2010 10:36 pm
Like Alex, I also hand-bend my sides with no water. Amazon RW is easier to bend than many EIR at the same thickness. I have an Amazon RW guitar(my first!) is on the belt.
Users browsing this forum: Terence Kennedy and 18 guests
