It is currently Fri Sep 19, 2025 5:56 pm
 Post subject: Removing super glue
PostPosted: Mon Jan 18, 2010 2:39 pm
First name: Matt
Last Name: Borland
When I was fretting my guitar project I accidentally spilled some stew-mac thin super glue on the neck. I put one coat of tung oil on the neck and there are obvious yellow stains where the glue spilled. What should I do to remove the super glue? The neck is flamed maple.
 Post subject: Re: Removing super glue
PostPosted: Mon Jan 18, 2010 4:12 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
CA debonder will soften the glue but if it is soaked into the wood it might not totally remove it. I got some on an acoustic top once and got it out but it was a pain and requires some sanding also.
Fred
Fred Tellier
PostPosted: Mon Jan 18, 2010 5:28 pm
If you had pore sealed with epoxy you will have to sand that area to wood re-pore fill. Other pore fills may react to the CA diffently Without taking the neck back to bare wood. no mater what you do you will likely have a noticable difference in hue there. How much of a difference is hard to know in advance.
