It is currently Fri Aug 15, 2025 2:08 pm
PostPosted: Thu Jan 14, 2010 6:12 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
I'm in the need of some more sanding strips for my Performax 16/32.
In the past I purchased the "ready-to-wrap" ones form Klingspor, but I'm guessing there's a more economical and better choice.
Suggestions?
P A U L B U R N E R
Burner Guitars
PostPosted: Thu Jan 14, 2010 6:49 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Paul;
try www.customsandingbelts.com
Mike Collins
PostPosted: Thu Jan 14, 2010 7:51 pm
I have bought for the Delta from:
www.industrialabrasives.com
They're swell.
David White, Toronto
PostPosted: Thu Jan 14, 2010 7:59 pm
Check your Klingspor catalog. They also sell longer, cut-your-own lengths.
michael propsom
www.propsomguitars.com
PostPosted: Fri Jan 15, 2010 8:33 am
Klingspor or Rockler sell rolls, which are at least 50% cheaper that precut strips. You can also get the rolls with printed cut marks, but they are fairly expensive.
In Markham,Virginia
PostPosted: Fri Jan 15, 2010 8:40 am
In Markham,Virginia
PostPosted: Fri Jan 15, 2010 8:48 am
First name: Matt
Last Name: Rispoli
State: NJ
When you guys run your wood through the thickness sander what level grit do you go up to. Just wondering if I should purchase higher grit.
thanks
matt
PostPosted: Fri Jan 15, 2010 9:07 am
First name: Big
Last Name: Jim
I sell the roll materials in my business , would be glad to get you price if u wish , need grit width desired and weight of the material , IE "J" or "X" weight cloth usally that info is on the back of the materials . also is it standerd or hook and loop , I dont sell the hook and loop materials.
wcaincj@aol.com is business email
PostPosted: Sat Jan 16, 2010 9:37 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I love my Klingspor "Blue" paper rolls. Last forever. Save one of your used strips as a template.
PostPosted: Sun Jan 17, 2010 5:27 pm
Last Name: Dunn
City: Wurtsboro
State: New York
Zip/Postal Code: 12790
woodworker.com has pre cut and uncut.
It is better to try and fail, than never try at all
