It is currently Fri Aug 15, 2025 7:36 am
PostPosted: Mon Jan 11, 2010 5:21 pm
First name: Kevin
Last Name: Halliburton
City: Pleasant Shade
Zip/Postal Code: 37145
I am currently making a template out of plexiglass and it is a half section. The flat side of the template, which is the centerline of the guitar; How does one true up that side in order to have a straight edge? I know to cut outside the line from other post and sand down to the line on the curves of the guitar, but a straight edge (on plexiglass) is the issue for me at this time. Is using a hand plane the way to go?
Also if anyone knows of a quick and adequate sized plan for making a workbench would be awesome.
Sorry about so many questions, but hopefully once I get the basics down and get started, questions will begin to answer themselves. Right now, it is so darn cold in TN (global warming) that it is hard to get out and get started.
Kevin
PostPosted: Mon Jan 11, 2010 5:28 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
You could take some sandpaper and stick it to a flat surface like a table saw and sand the edge .I use that stuff stew mac sells that has stickum on the back of the sandpaper.Or you could just tape the sandpaper down.Takes a lot of elbow grease,but that`s free.
James
James W Bolan
Nashville Tennessee
PostPosted: Mon Jan 11, 2010 5:30 pm
First name: Tim
Last Name: Caccamise
City: Moreno Valley
Zip/Postal Code: 92557
Kevin,
if you have a jointer, that will work great. If not a plane and a shooting board will work. Another option would be to attach the plexiglass to a board you know is true and run it through your table saw using the true edge along your fence.
Tim
PostPosted: Mon Jan 11, 2010 5:32 pm
That needs to be the first step in fabricating the template because that edge is the datum for everything else. but you probably know that but I thought I throw it in for others that may not know.
PostPosted: Mon Jan 11, 2010 5:35 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Sorry I forgot to answer the work bench question.You can go to the Borg and buy a solid core door and a few 2x4`s and make a pretty decent workbench real cheap.Mine even has a shelf below the work top for storage.You`ll realize that when building guitars you`ll come up with a ton of ingenuity to save a lot of money.
James
James W Bolan
Nashville Tennessee
PostPosted: Tue Jan 12, 2010 7:28 pm
A diablo blade and a table saw will also do the thick.
All kind of good plans here:
http://plansnow.com/
I made mine from modifying this one. Drawers on both sides and longer , wider and lower for my comfort. The top I glued up 2 X 8s. Well, you really didn't expect me to make it the same as the plan. :P
http://plansnow.com/wwrkbnch.html
PostPosted: Tue Jan 12, 2010 7:39 pm
Template? Were it mine, I'd probably take it to work and mill the edge. At home, I'd sandwich it between some wood and clamp a straight edge like a (24" steel rule) to the top of the whole thing and use the rule as a guide for my super-duper Hitachi router along with a spiral fluted cutter say 1/4" diameter or so. IMO planing it will just take too long and you'll need to check the cut with a straight edge anyway.
Work bench? there are many plans available on the internet. Google "workbench plans" [:Y:]
PostPosted: Tue Jan 12, 2010 8:26 pm
Last Name: Abercrombie
Kevin-
About the workbench:
You don't need anything very complex- just make sure that you have something solid with enough overhang so that you can clamp jigs and fixtures to the bench.
I took a building course with Sergei deJonge a few years ago and was surprised by how simple and compact the workbenches were- the students used the same-size benches as the pros (I include the 'apprentices' in the 'pro' category- they were v. good) in the shop who were turning out amazing guitars. (well, Sergei's bench was a bit bigger than the rest... ;) )
I got some good ideas for my shop when I was at Sergei's.
http://www.dejongeguitars.com/about-myshop.html
Note the overhead shelf which is the go-bar top deck.
You can also get some good ideas from Warren Gash's pictures from the deJonge shop.
http://www.youtube.com/watch?v=Xj4_IIeGPHg
PostPosted: Wed Jan 13, 2010 3:13 am
First name: Kevin
Awesome John.
Kevin
PostPosted: Wed Jan 13, 2010 10:58 pm
First name: Kevin
I was looking at lumber at Lowes and ran across this workbench plan for anyone interested. Kevin
http://www.lowes.com/cd_Build+a+Workben ... -_-22617_3
PostPosted: Thu Jan 14, 2010 3:22 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I agree with Michael - the straight edge of a template is the first thing you should work on. You can use a plastic-cutting blade in a table saw to get it straight enough normally. If you want it super-accurate, you can clamp it in a homemade jig with an inlayed precision metal straight edge and then, using a pattern routing bit in a router table, with the bearing riding on the metal straight edge, route the edge of the template so it's the same straightness as your reference straight edge. If you've already cut the curvy part of the template, you could maybe rough cut the straight edge with a bandsaw, just outside the line, then pattern route it as above, otherwise your best bet might be to start over.
Dave F.
Cambrian Guitars
PostPosted: Thu Jan 14, 2010 11:35 am
I'll second that!
PostPosted: Fri Jan 15, 2010 7:57 am
On the workbench side of things, I built this (wihtout the optional drawers) and it is a real workhorse. Solid as a rock. I have since modified the same design to build a couple 30x24x42 versions for assembly. It is simple, cheap, and works great.
http://www.plansnow.com/weekworexvie.html
PostPosted: Fri Jan 15, 2010 8:37 am
That's the same as mine. :D
You can download the plan for $5 too.
Users browsing this forum: bobgramann and 13 guests
