It is currently Fri Aug 15, 2025 4:22 am
 Post subject: Parlor Plans?
PostPosted: Tue Jan 12, 2010 4:59 pm
I have a question about parlor plans.
LMI is selling one of the Scott Antes Plans
http://www.lmii.com/CartTwo/thirdproduc ... cott+Antes
Does anyone have an pics of guitars built with these plans?
He seems to have two different parlor plans out there, a "6 string small concert parlor" and the "1885 Bruno" plan. I am trying to figure out which plans LMI is selling. http://www.pilgrimsprojects.biz/guitar.html
I could just call them, but I am sure someone here has probably built one.
 Post subject: Re: Parlor Plans?
PostPosted: Tue Jan 12, 2010 5:26 pm
Last Name: Cox
I believe the 1885 Bruno is a plan for a gut/nylon string, ladder braced guitar...
I think the Small Concert parlor is an X-braced Steel string plan...
My guess is that this plan is the small X-braced steel string... but I would call them to make sure.
To throw a wrench into the works... He also has a small "Tenor" ladder braced guitar plan as well!
Someone please correct me if I am wrong.
PostPosted: Tue Jan 12, 2010 5:45 pm
GAL has plans for a small-bodied Martin drawn by the late Ted Davis. I think but am not sure it would be considered a parlor.
In Markham,Virginia
PostPosted: Tue Jan 12, 2010 6:36 pm
Brock,
I have the LMI plan. Is there anything you need to know about it? It is definitely an X braced plan.
Mike R.
PostPosted: Tue Jan 12, 2010 6:39 pm
Brock, I'm surprised you just can't make your own plan. Maybe get a tracing of one and the measurements is all I would think you would need. You probably are going to do your own thing with the bracing anyway.
The Ted Davis plans at GAL are for a Martin 1-18 .. X braced, single tone bar, 12 fret, 24 7/8 scale - definitely a parlour (though I consider anything 0 or smaller a parlour)
PostPosted: Tue Jan 12, 2010 6:46 pm
Brock...I've made 2 from a modified Antes plan. Sitka over Cherry and Redwood over Walnut. Here's the latter http://www.donohueguitars.com/component/content/article/40-available-guitar-models/96-parlor-guitar
PostPosted: Tue Jan 12, 2010 8:06 pm
I can, I have been waffling between making my own and modifying an existing body shape.
PostPosted: Tue Jan 12, 2010 8:07 pm
Thanks JJ. This is exactly what I was looking for. (Nice guitar!)
PostPosted: Tue Jan 12, 2010 8:10 pm
Yeah, I saw that... I need something definitely smaller than an 0.
PostPosted: Tue Jan 12, 2010 11:24 pm
I've made several from the same Antes plan as JJ. They are pretty much a Martin size 2. I used a 24.9 scale and a double tenon bolt-on carbon reinforced neck. I splayed the X a little more and lengthened the bridge to around 6.5". Modified the brace dimensions a little. They are great little guitars. Here's a link to one with a sound clip.
http://www.thepodium.com/p-16705-kenned ... dlutz.aspx
PostPosted: Wed Jan 13, 2010 9:19 am
Thanks!
I can't make the link work. Can you check it.
PostPosted: Wed Jan 13, 2010 10:58 am
It worked for me Brock but here it s again. You could also go to thepodium.com and under "Browse By Brand" click on "kennedy"
Terry
PostPosted: Wed Jan 13, 2010 11:11 am
Cool it worked that time. Thanks!
That is a nice guitar.
PostPosted: Wed Jan 13, 2010 12:29 pm
First name: Hugh
City: Lake Oswego
State: oregon
I made this video a few years ago. I hesitate to show it, it has so many mistakes, but it is from the antes plan AGP-01. It has a bit throatier sound in the treble than the Kennedy sample for some reason.
http://www.youtube.com/watch?v=ECoG6jY9Imw
PostPosted: Wed Jan 13, 2010 2:49 pm
First name: Rick
Last Name: Davis
City: Seattle
Brock --
I have (my own) plans for an 1840's Ashborn. Not a Martin -- a 11 1/2" lower bout/ 17 3/4" length/ 24.5" scale. The bracing is a modification of the original narrow X. I've made 3 or 4, the first wasn't too successful so I widened the X bracing. The later ones were much nicer with the typical Parlor sweetness, response, and low volume.
For those who don't know about Ashborn, it was a highly successful factory near modern Torrington, CT, making banjos and guitars in the first half of the nineteenth century. Ashborn held patents on a number of instrument-related products, including a very cool friction tuner. The Civil War must have affected business, Ashborn himself was elected to Congress (as a strong supporter of abolition and Federalism), and the factory closed. Many of the features of early Martins are also found on Ashborn guitars -- as to which came first, I'm not qualified to say.
PostPosted: Thu Jan 14, 2010 8:41 am
G'day Brock,
I have just finished a concert sized guitar built to the Scott Antes plan from LMI.
Here are a couple of sound samples,
http://www.soundclick.com/ozziebluesman
light my fire finger picked and still got the blues with a pick.
Alan
PostPosted: Fri Jan 15, 2010 8:29 am
Very nice guys... Thanks.
