It is currently Wed Jul 23, 2025 1:13 am
PostPosted: Thu Dec 31, 2009 5:37 pm
First name: Sam
Last Name: Ryan
State: VA
Zip/Postal Code: 22207
I'm working on my first guitar-building project and recently purchased the Fox Universal Side Bending Machine. I built the template-jig (photo attached) today but had a question before I try this out. Two of the steel rods aren't perfectly flush with the side leaves. In both cases, the circumference of the rods project about 1.5 millimeters beyond the top-edge of the side leaves. Is this something I need to fix before going live? In other words, will this tiny projection end up causing a crease (or bump) in the rosewood when I bend it to make the sides? Or will a projection that small not really make a difference once I clamp the sides into the mold after bending. I'm hoping that once I bend the sides and then clamp them into the mold, such tiny imperfections will be evened out. But I figured I should check first before I risk ruining a nice piece of rosewood. Thanks in advance for any advice.
PostPosted: Thu Dec 31, 2009 6:33 pm
Greeting Sam and welcome to the forum.
Are you saying that the diameter of the steel rod is not tangent to the contour of you template?
PostPosted: Thu Dec 31, 2009 7:04 pm
First name: Sam
Last Name: Ryan
State: VA
James -- thanks. And yes. That is correct. It is not perfectly tangent. Hopefully my pic below makes it more clear.
PostPosted: Thu Dec 31, 2009 7:07 pm
Probably won't make a bit of difference, but I would fix it just because it would bug the you-know-what out of me.
Cheers,
Gwaltney Guitars
PostPosted: Thu Dec 31, 2009 7:27 pm
First name: Tim
Last Name: Caccamise
City: Moreno Valley
Zip/Postal Code: 92557
I would fix it, why take the chance that it will cause a problem.
Tim
PostPosted: Fri Jan 01, 2010 7:02 am
First name: William
Last Name: Stewart
City: Hawick
State: Roxburghshire
Zip/Postal Code: TD9 9NB
Country: Scotland
I would file the holes down a bit to get the rods flush. Otherwise you could have a slight skew/twist on your finished bend.
My tuppence worth.
Happy New Year Eat Drink
Bill S.
Dream to be a luthier
PostPosted: Fri Jan 01, 2010 7:40 am
If you are using a building mold or form you are fine and you won't need to do anything as the mold is what will determine the shape anyway .
PostPosted: Fri Jan 01, 2010 1:51 pm
Last Name: Garrish
I'd grind it level, but as John says it won't really effect your side much (they move quite a bit no matter how well they're bent). If you ever try to make laminated sides, though, you'd best be sure your form is spot on.
Bob Garrish
Users browsing this forum: DennisK and 21 guests
