It is currently Thu Aug 14, 2025 10:26 am
PostPosted: Thu Dec 17, 2009 1:48 pm
First name: Benjamin
Last Name: Castincaud
City: Niort
Zip/Postal Code: 79000
Country: FRANCE
For my second guitar, with a LP style neck and a 13° headstock angle, the thickness of the virtual blank (I used a scarf joint) is 2,3".
Hope, it will help... ;)
PostPosted: Thu Dec 17, 2009 3:58 pm
City: Niort
Country: FRANCE
2.3" thick... ;)
For the laminated neck without scarf, I've done it for my first guitar, an explorer type, 26" scale, 5 laminations (3 maple, 2 wenge) and it is still there... :D
A little tip for gluing a scarf joint on a laminated neck, without the "slipping" issues : http://www.lutherie-amateur.com/Forum/v ... 34#p290734
Ben
PostPosted: Thu Dec 17, 2009 4:43 pm
Hmm...
When I do a laminated neck (but no scarf), I do a three piece. I use 1x3's which are 3.5" x 0.75". This causes the neck to be 2.25" wide and has enough room for a fairly large headstock.
The 2.25" wide leaves a bit of room at the body/neck joint to trim. I think the 15/16th fret where most join is around 2-1/8" wide or so.
Headstock size is going to be your determining factor on how tall the neck needs to be. Most gibson size headstock will fit in that 3.5" width.
J
Joe
