It is currently Thu Aug 14, 2025 9:19 am
 Post subject: Router bits
PostPosted: Thu Dec 17, 2009 11:39 am
Would the 1/4" downcut end mill from LMI be a good choice for binding? I am going to be using a setup with an adjustable bearing so I need something 1/4". Also, what would you say is the most versatile size of inlay bit?
 Post subject: Re: Router bits
PostPosted: Thu Dec 17, 2009 12:52 pm
I use a 1/4" downcut spiral carbide router bit. Works great and leave a very clean surface.
PostPosted: Thu Dec 17, 2009 1:01 pm
Here is the one I am referring to:
http://www.lmii.com/CartTwo/thirdproduc ... =End+Mills
Its in the picture under code SPPRC
PostPosted: Thu Dec 17, 2009 1:26 pm
I've used a 1/4" downcut bit for binding channels and it worked great. Check out Routerbits.com which is about $11 less than LMI.
For inlay work, I use 1/32", 1/16" and 1/8" bits. I've just used upcut bits on the 1/32" as I feel there is little advantage of having downcut for such a small bit. The others I use downcut to make the edge cleaner.
PostPosted: Thu Dec 17, 2009 1:55 pm
First name: Heath
Last Name: Blair
City: Visalia
i would also recommend http://www.mlcswoodworking.com. free shipping on all of their bits all of the time. ive ordered several and they seem to be good bits. 1/4" spiral downcut for binding works well. i cant comment on inlay as i havent done any.
sweat the small stuff.
PostPosted: Thu Dec 17, 2009 2:02 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
For the inlay bits, I found very nice ones on ebay: http://cgi.ebay.com/10-Piece-Carbide-Bu ... 230373306b
All kinds of sizes, 10 in a pack. (this is the seller I bought them from)
PostPosted: Thu Dec 17, 2009 6:30 pm
Those all look like good sources guys and I will tab them for later use, but I need to get stuff from LMI so its easiest just to get it all shipped from the same place. My main question was just if that 1/4" "end mill" bit is the same as the regular 1/4" downcuts people use for binding. Is end mill essentially another word for router bit?
PostPosted: Fri Dec 18, 2009 3:36 am
Last Name: Garrish
Yes
Bob Garrish
Users browsing this forum: Ken Lewis and 25 guests
