It is currently Sat Aug 16, 2025 1:54 am
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2
 Post subject: Re: Go bars
PostPosted: Mon Dec 14, 2009 3:56 pm
+1 on making the height adjustable. I started out with a fixed height and wood bars. That worked but I soon found myself using a lot of different lengths and finally went to the all-thread and 24" fiberglass go bars. Put some vinyl tubing around the area of all-thread where you'll be moving parts in and out so if you hit the wood on it you won't damage it.
PostPosted: Mon Dec 14, 2009 4:22 pm
It's simple column buckling theory.
the load will be inversely proportional to the length squared
So yes the length matters significantly.
If the shelf height for 24" bars is too low for you, make some riser boxes you can place on the benchtop.
PostPosted: Mon Dec 14, 2009 4:37 pm
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
I've used different dia. size dowels for gluing way before I starting building a guitar. I used maple 5/16 X 36" dowels for my deck and requires a bit more perfection with distance...but they're cheap enough that I cut them down if necessary and use them up with my business anyway. I find they have more than ample pressure to do what is necessary. I contemplated fiberglass bars...but OH...Man they are expensive.
Kent ( the Cheapskate ) Bailey
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Mon Dec 14, 2009 4:43 pm
Exactly right 24" at 3/16 diameter will produce between 7.5#-8.5# of dow force once it starts bending. It dows not mater how much you bend them. Once you reach the bucking point (pretty much moment the rod starts deflecting or bending) that is as much pressure you will see from any given length. IF you want 8# at 48" long you are pretty much going to have to buy 1/4" rods to get there.
PostPosted: Mon Dec 14, 2009 4:50 pm
3/16" x 48" are $1.90 each. Get two 24" go bars from each one - not expensive at all. Mine measure 7 lbs force each with about 2" deflection.
http://www.intothewind.com/shop/Repair_and_Kitemaking/Fiberglass_Rods_for_kites/3-16_FG_Rod
PostPosted: Mon Dec 14, 2009 4:59 pm
I want to say here for the sake of those that may not know. You gain no extra clamping force by bending more than 3/4" to 1" you only add restrained spring loading. I never bend my rods more than 1". The added spring load does nothing for clamping pressure but can cause the rod to come loose and fly across the room or poke through your top if bumped . Keep the spring loading to a min and you will never have a rod come lose and punch a hole or bad dent in your tops.
Last edited by Michael Dale Payne on Mon Dec 14, 2009 5:02 pm, edited 1 time in total.
PostPosted: Mon Dec 14, 2009 5:00 pm
I have been using the same maple go-bars for years and none have ever broken, gotten tired, or given any problems. I made them from scraps in the free "ripping pile" at the local hardwood sales shop. I have two sets, one is 3/16" square and the other is 1/4" square and a few that are 3/8". All are ~30" long, I just made them fit to the space aloted for the deck. The different sizes get used for different processes and I can make more if necessary but I never had the need.
Alan D.
PostPosted: Mon Dec 14, 2009 5:18 pm
I have wood slats that I have been using for a couple of years. They're made of some oak that I found in a scrap heap. I have two sets. One of the length for braces and another for tops and backs. I've had a couple break due to runout, but it's easy to just cut a few more if I need them.
Walter
Walter Lay
"It's taken me so long, but now that I know
I can see. All that I do or say, is all I ever will be"
- Billy Joe Shaver
PostPosted: Mon Dec 14, 2009 6:22 pm
bluescreek wrote:
Length will have little to do with overall pressure . Instead of 8lb the 48 inch may be 7ish but expect something close to the 8 to 10 lb ranges for best results. Now if you are looking at 20 feet that may be a bit different .
That comment really surprised me coming from an engineer. John, this is pretty basic physics and is misleading.
bluescreek wrote:
Wood will work short term but they can break and weaken but if you have an endless supply and you don't mind making them , go ahead , they will do the job. I found hickory and elm to be the best for wood . but it is hard to find them without runout.
People have been using wood for go-bars for hundreds of years now with no complaints. I've been using the same strips of maple for the past 4 years now. None have broken. All work just as well as the day I cut them. They cost me my time to rip them to size (which was about 5 mins for 40 sticks). I use off cuts or scraps from hardwood flooring (the pre-made, finished stuff). It's 3/4" thick and I just rip them to 1/4" wide and I'm done (I have about 42" between top and bottom of my deck). If I need them to be shorter for gluing the top or back on, I just cut them.
They work just fine, cost less and are environmentally friendly too boot (think recycling).
PostPosted: Mon Dec 14, 2009 6:41 pm
I should of gotten thicker ones, but I understand why someone recommended this diameter as 24" is the most common deck height. I am trying to think of a way to make 24" bars work with my deck, but the shelf I am building on top is going to be heavy and would be difficult to make it adjustable, also the bench top is all built already so I cannot heighten that. I am thinking I will just use a bunch of 36" bars for every glueing operation. Thanks for all the replies guys.
PostPosted: Mon Dec 14, 2009 7:05 pm
First name: Heath
Last Name: Blair
City: Visalia
how heavy is your top shelf going to be? i just weighed mine and it was 33 lbs. not exactly a light weight. its 2 layers of 3/4" MDF 24 1/2" x 34". no problems moving it up and down.
sweat the small stuff.
PostPosted: Mon Dec 14, 2009 7:11 pm
Edward, make a riser box to raise the bench height. Make is removable to you can use the bench and a lower height like you want to.
I sure do like having lots of room to work in my built in go-bar deck.
PostPosted: Mon Dec 14, 2009 7:52 pm
First name: Jonathan
Last Name: Jones
City: Nuneaton
Just wondering, but how many go-bars do you think it is necessary to have?
Jonny
"Anything that happens, happens. Anything that in happening causes something else to happen, causes something else to happen. Anything that in happening happens again, happens again. Though not necessarily in that order." Douglas Adams
PostPosted: Mon Dec 14, 2009 9:40 pm
It is going to be a 30"x48" of 2x4 frame with a plywood top and bottom. It would be quite an operation to rig something up to move that up and down easily.
PostPosted: Wed Dec 16, 2009 8:37 pm
First name: jeff
Last Name: parker
City: anchorage
State: ak
Zip/Postal Code: 99516
As you build the go bar deck consider how you access the object you are glueing. I have found having a deck that is movable is handy so I can turn it and access it from any side. This is handy for placing bars or for cleaning glue. In my experience 3/4 plywood top has been strong enough to hold up to 15 fiberglass rods although the plywood does take on a noticable bend.
PostPosted: Wed Dec 16, 2009 9:40 pm
Jeff, my deck is part of a 12 foot long bench bolted to the wall. Maybe I will make a smaller one eventually too. Welcome to the OLF by the way. [:Y:]
PostPosted: Wed Dec 16, 2009 10:06 pm
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
For reference, I made my deck with a couple of finished 2x2x.75 pieces of plywood, some all thread and a few chunks of 1x3 pine. I use it with 24" glass go bars. It's great for braces, as well as assembling tops and backs to rims. I set it off to the side and use it as a table when it's not being used as a go bar deck. I have about 48 go bars and they stick through the holes in the top rim for easy access. The 1x3 frames top and bottom keep the 2x2 plywood from flexing.
HTH,
Chris.
PostPosted: Wed Dec 16, 2009 11:20 pm
First name: Heath
Last Name: Blair
City: Visalia
chris, youve got a crazy mixture of gas piping and electricity there in your shop! sorry, i work for a major gas utility and when i noticed i had to say something. wow7-eyes
PostPosted: Thu Dec 17, 2009 7:59 am
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
I found my rods at the local Lowes. They have 48" fiberglass rods just like the kite store sales. These are in the "for sale" sign area in hardware. I am pretty sure it was Lowes, if not then it was Home Depot.
BTW if it is not obvious make sure you wear safety glasses.
R
PostPosted: Thu Dec 17, 2009 10:49 am
I don't think this has been mentioned yet, but cutting fiberglass gobars with a bandsaw blade is a surefire way to motivate you to purchase a new bandsaw blade. oops_sign gaah
Don't ask me how I know this.
PostPosted: Thu Dec 17, 2009 10:59 am
I taped mine into a bundle and cut them with a Dremel metal cutoff blade. Quick and easy - dont' breathe the dust.
PostPosted: Thu Dec 17, 2009 4:41 pm
Yep, I said blade, meant wheel.
Users browsing this forum: TimAllen and 12 guests
