It is currently Thu Aug 14, 2025 10:33 am
 Post subject: Density Calculator
PostPosted: Sun Dec 13, 2009 11:24 am
First name: David
Last Name: Schramm
Just found this cool density calculator
http://www.indoorduration.com/BalsaCalc2.asp
 Post subject: Re: Density Calculator
PostPosted: Sun Dec 13, 2009 12:19 pm
Nice little applet. It says for balsa, but it seems it shouldn't matter. I mean, density is just weight/volume, right?
PostPosted: Sun Dec 13, 2009 1:22 pm
Right.
But, as I asked in another thread, what is "standard" convention for luthiers??
This takes gms & inches & calcs lb/cu.ft. I calculate gms/cc. Brock uses gms/cu.in. What's everybody typically use?
Milton, ON
PostPosted: Sun Dec 13, 2009 1:55 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
That's my other hobby, indoor duration models, we use mixed measurements all the time as the weight of balsa spars and such has too many decimal places in ounces. When you build planes weighing in the range of 1 gram or less total weight the decimals become a pain. We are even more nuts than left brain guitar builders as all the parts are flex tested and weighed so to keep the completed plane weight as low as possible with acceptable strength.
Fred
Fred Tellier
PostPosted: Sun Dec 13, 2009 2:16 pm
Last Name: Abercrombie
Dave Stewart wrote:
Right.
Standards? [uncle]
My inclination is always to use g/cm^3 like you, since it neatly matches with specific gravity (S.G.).
I notice that Alan Carruth uses kg/m^3 which is another 'standard' density unit that gets rid of the decimals for our uses.
Then of course there's the mm vs fractional inches vs decimal inches thing......not to mention left handed and right-handed tape measures....
PostPosted: Sun Dec 13, 2009 3:12 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
I'm not sure of a lutherie standard, but I like that reasoning, too. pcf seems to be the standard in US forestry/lumber, so that can be helpful to follow. But g/in^3 is convenient for luthiers in the US.
Fred, Wow -- an airplane less than 1 gram.
David Malicky
PostPosted: Mon Dec 14, 2009 6:00 pm
First name: Rob
Last Name: Thompson
Dave Stewart wrote:
Right.
When building with Gopherwood, I like to use shekels/per cu. cubit :lol:
Peace,
Sanaka
...imagine there were no hypothetical situations...
