It is currently Wed Aug 13, 2025 3:07 pm
PostPosted: Thu Dec 10, 2009 6:45 pm
City: Jacksonville
The picture you see in this post is of a binding job that was done on a Bajo Sexto. It's a really big Mexican guitar. The binding is roughly 200 thou square. According to 'sources'...it's pine and walnut...but that's not what I really need help with.
Can anyone tell me how to do this??? More specifically - how to get it to bend in the waist area? Everything I've tried so far has broken.
PostPosted: Thu Dec 10, 2009 6:53 pm
First name: Tracy
Last Name: Leveque
State: CO
This kind of looks like one of Edward Dick's guitars he did for the millennium. He used ebony and MOP. He glued in each block one at a time. That may be what you need to do. Good luck!
PostPosted: Thu Dec 10, 2009 7:22 pm
City: Jacksonville
This block scheme on this guitar has the blocks tilted somewhat at an angle...I can't gather (in my head) how you manage to install them cleanly AND at an angle....
PostPosted: Thu Dec 10, 2009 7:39 pm
First name: John "jd"
City: Santa Barbara
I build these as approx 6" x 12" blocks with strips at 45 degrees
glue it up clamped over wax paper to a plywood carrier. Once dry trim and joint 1 edge,and then rip to width and trim ends at 45 deg to match the strips.
glue the blocks with polyurethane (gorilla) or plastic resin glue and you can use heat to bend it.
-jd
PostPosted: Thu Dec 10, 2009 11:01 pm
City: Duluth
State: MN
Chris, Ron Steiger has done some of these, you may wanna ask him. IIRC, he put veneer strips on the inside and the outside. The inside ones were left on, as purflings, and the outside one just helped hold it together - they were installed purposely sticking up proud of the rims and subsequently trimmed off with a router. I may be blending 2 builders' technique together, but ask Ron.
Dennis
Dennis Leahy
Duluth, MN, USA
7th Sense Multimedia
PostPosted: Fri Dec 11, 2009 10:10 am
City: Jacksonville
Ron Steiger... Harpguitar.info
Got it.
Keep it coming folks...Is there anyone that has actually done something like this on this forum?
PostPosted: Fri Dec 11, 2009 10:21 am
This is for the ukulele, but it should work on a guitar. http://uketalk.com/luthier-tutorials/rope-binding.htm
Doug
PostPosted: Fri Dec 11, 2009 10:26 am
Joe Kelly has one he shows in his avatar. His are not on an angle like this, but same idea.
I like Dennis' solution.
PostPosted: Fri Dec 11, 2009 10:29 am
And if you don't want to mess around, I sell those bindings already made, and the b/w/b purfs as well.
PostPosted: Fri Dec 11, 2009 1:47 pm
City: Jacksonville
Shane do you have any pics of this binding you sell? Would love to see it.
Users browsing this forum: meddlingfool and 13 guests
