It is currently Thu Aug 14, 2025 4:43 am
PostPosted: Thu Dec 03, 2009 4:08 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
Making my first Florentine cutaway - and while routing the binding channel I had a piece of wood chip out.
I went ahead and did the purf and binding hoping that I would be able to fix it down the line. It is time to fix this.
The wood is Claro Walnut.
Should I fill with Walnut dust and CA over the top to wick in - or will that drastically change the color of the Walnut?
Should I mix Walnut dust with Titebond and fill the chip out?
Suggestions I haven't thought of???
I'm too new at this to know what to do.
I DO know that next time I will mitre the point where my tip seam is!
P A U L B U R N E R
Burner Guitars
PostPosted: Thu Dec 03, 2009 4:18 pm
Hey Paul, bummer that!
I think there are two options for you, but first off... Don't use glue and dust for that big of a chip out. I did it on #2 and it just doesn't look right. The coloring doesn't match well.
Option # 1: Use an exacto blade to cut out the offending area in a wedge shape, take some scrap walnut from the side (hopefully you have some) and make a wedge to fit and glue it in place with either CA or titebond.
Option # 2: Bind the point. Now that will take a bit more finesse but it can be done. You would need to score the side from purfling line to purfling line, both sides of the point. Just work at it patiently till you get down about 1/32-3/64". Use a nice sharp chisel to remove the side material, get it as flat as you can. Then just miter the purfling lines and install some more ebony binding and purfling. Fill any gaps in the point with ebony dust.
Personally, if it were me, I'd bind the point.
Nice job on the top miters too [:Y:] This is going to be nice looking guitar.
PS: Note to self! When cutting binding channels on florentine cutaway's, always cut the outside edge first with a climb cut, but control the router well.
PostPosted: Thu Dec 03, 2009 4:22 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Rod,
The chip out is actually larger than the width of my binding - so binding the tip wouldn't fix the entire problem.
Thanks for the other idea of inserting a wedge piece of wood. I had thought of that but wasn't sure that was the best option - but it may be.
P A U L B U R N E R
Burner Guitars
PostPosted: Thu Dec 03, 2009 4:25 pm
Paul,
What Rod said. I would add that what you'd be doing is inlaying new wood. Sort through your scraps and you'll likely find a piece with matching grain. With some care, you could make this nearly invisible.
PostPosted: Thu Dec 03, 2009 4:27 pm
Ya, I was wondering if it was to big for the binding to hide entirely.
PostPosted: Thu Dec 03, 2009 6:01 pm
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
Yes...the wedgy is the best solution and actually much easier than it sounds. If you have some side scraps, just hold pieces up to the area and look for color and grain similarities. It's still small enough an area that a tight fit and a close match will not show.
Kent Bailey
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Thu Dec 03, 2009 6:05 pm
Would the best way to avoid this be to leave the last bit on the point and do it with a chisel?
PostPosted: Thu Dec 03, 2009 6:06 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Kent Bailey
I've got some scraps from the bending and other cut-offs from the build - so I should be able to find something that matches. Good ideas.
P A U L B U R N E R
Burner Guitars
PostPosted: Thu Dec 03, 2009 6:22 pm
PostPosted: Thu Dec 03, 2009 7:11 pm
I would use both of Rod's options then you will have very little of the chip out repair visible.
Ken Franklin
clumsy yet persistent
PostPosted: Thu Dec 03, 2009 10:09 pm
Rod's idea is good. Use liquid hide glue or titebond, it will make it less noticeable.
PostPosted: Thu Dec 03, 2009 10:30 pm
First name: george
Last Name: wilson
City: barhamsville
State: virginia
Zip/Postal Code: 23011
Country: united states of america
Yes,you must use a solid wood wedge to fill it. Use anything else and in a few years the repair will be a different color from the other wood as it ages.
PostPosted: Sat Dec 05, 2009 4:57 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Thanks to all of you who suggested that I cut the chip out area into a nice even wedge - and then make a wedge of similar walnut to fit.
I am amazed at how well this worked - from the inside of the cutaway you can hardly tell there was a problem.
On the outside of the cutaway you can see a little - but that is normally out of your normal view.
So - here's what it looks like.
I'm VERY happy with the results.
P A U L B U R N E R
Burner Guitars
PostPosted: Sat Dec 05, 2009 6:23 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Nice Job Paul! I am relieved to see how well that worked for you, because I had to do a similar repair to the top of a guitar I am working on. I couldn't believe it when I whacked the top with a steel ruler! Doh!
I bought a small gouge & cut a "U" shaped piece out. Using the same gouge, I cut a repair insert from a sister top. I tried it a couple of times on scrap before committing to the process & it worked really well. Almost invisible repair. The clamp is still on & I'm going to give it a full day for the fish glue to dry. Fingers crossed... I really don't want to take the top off & start again!
PostPosted: Sat Dec 05, 2009 6:47 pm
Yesssssssss!!!!
Great outcome. Under finish, you'll be hard pressed to find it, unless you know it's there.
PostPosted: Sat Dec 05, 2009 10:19 pm
Paul,
if you don't mind me asking, whats that line all running all the way down the cutaway?
Nice job repairing the chipout!
PostPosted: Sat Dec 05, 2009 11:49 pm
Very nice job Paul. I can't see where there is any difference between the parant wood and the repair, AT ALL! [:Y:]
Again, great job on the top mitres, those are not easy and you did a great job on them.
PostPosted: Sun Dec 06, 2009 12:56 am
Last Name: Burner
City: Lincoln
State: Nebraska
peterm wrote:
Paul,
Peter - this is my first florentine cutaway and I did a butt joint at the tip instead of a mitred joint. I will definitely do a mitred joint next time.
So - the line is where the two pieces of wood are joined.
P A U L B U R N E R
Burner Guitars
PostPosted: Sun Dec 06, 2009 3:40 pm
Oh, I see....
PostPosted: Sun Dec 06, 2009 4:53 pm
Paul, even if it's your first florentine I think you will be happier over time if you bind the cutaway ridge and hide the lap joint. What you have will be more pronounced under the finish. It can be done fairly easily by sawing out the ridge and replacing it with a triangle of ebony and some veneer.
Ken Franklin
