It is currently Thu Aug 14, 2025 7:19 am
PostPosted: Thu Dec 03, 2009 7:41 pm
I've just been given by my friendly luthier a bottle of water based lacquer, his supplier sent it to him as a sample, it's a bottle labeled Water Based High Solids Self Cross-Linking Lacquer Gloss, Mylands is his supplier, there is no directions on the bottle and the website just says 5% dilution with water max. It's an opaque white liquid that smells faintly like pear drop sweets. I'm guessing it needs spraying using a largish nozzle size. he only touches in repairs and has to sends out full spray jobs due to living in a basement flat and is concerned about neighbours, so has no use for it any ideas guys?
Tips on nozzle size, pressure etc would be gratefully reiceved
Formerly JJH
PostPosted: Thu Dec 03, 2009 7:58 pm
City: Hartselle
State: Alabama
I've been spraying KTM-9 using a Devilbiss Finishline 2 HVLP gun, 1.4mm tip, compressor set at 40psi and dropping the pressure a bit more at the gun. I thinned the lacquer a bit with denatured alcohol rather than water on the last one, and was pretty satisfied with the results.
Kent
Facebook Page
PostPosted: Fri Dec 04, 2009 6:56 am
First name: joe
Last Name: kelly
City: glasgow
Country: uk
hi john the stuff you have got is called aquabuild and its made by these guys http://www.frenchpolishes.com/products/aquabuild.htm
it dries very very very hard.........too hard........i spray it out the bottle through a 1.2mm nozzle and use hvlp it dries mega fast......i may change to this stuff as i hate paying to import from target coatings
joe
PostPosted: Fri Dec 04, 2009 6:57 am
First name: joe
Last Name: kelly
City: glasgow
Country: uk
i forgot to say these guys make it and rebrand it for other people
PostPosted: Fri Dec 04, 2009 7:31 am
Joe there seems a few discrepancies between the product described in your link and the one on Mylands website http://www.mylands.co.uk/products/wood_ ... based_scl/ most notably the coverage thanks for the nozzle and pressure advice guess its just have a go now.
Formerly JJH
Users browsing this forum: Chris Ensor and 12 guests
