It is currently Wed Aug 13, 2025 1:31 pm
PostPosted: Fri Nov 27, 2009 4:08 pm
First name: Jonathan
Last Name: Coleman
City: Lacona
Zip/Postal Code: 13083
My current pickup that I use is an LR baggs M1 active paired with an LR Baggs para acoustic DI. my old pickup was a fishman classic 4 UST. my initial thought was to tie the two pickups together through the existing predrilled hole in the tail block. unfortunately the M1 active cant be wired together with the classic 4 due to the differences in battery voltage. so what I was wondering is this...
can I drill another whole through the tailblock for the classic 4? I know that I have to keep an eye out for the JLD bridge truss but would drilling another hole be a bad idea as far as structual integrity is concerned?
also should i use a brad point bit, a woodboring bit or a standard titanium bit?
I really would rather have a mic installed to blend with but Im saving for tonewood instead.
thanks in advance for the replies
PostPosted: Fri Nov 27, 2009 4:20 pm
I have seen many professional guitarists with two jacks drilled in the end block, I really do not think it would be a problem.
PostPosted: Sat Nov 28, 2009 12:07 pm
Been done many times .... I recently picked up a titanium coated step drill for the jack/strap hole - it doesnt blow out the inside like a forstner/brad can.
Users browsing this forum: bcombs510, rbuddy and 10 guests
