It is currently Thu Aug 14, 2025 7:06 am
PostPosted: Fri Nov 20, 2009 10:25 am
First name: Peter
Last Name: DeWitt
City: Columbus
State: OH
Zip/Postal Code: 43201
I plan to use double upper tansverse braces. My bracing stock is Lutz. Anybody have suggestions on what width and height I should probably make each of the UTB's? If it matters, the upper bout is about 11" wide on my model.
Peter
PostPosted: Fri Nov 20, 2009 10:41 am
Hey Peter,
I use two larger upper transverse braces, each is 3/8" wide x 5/8" high.
PostPosted: Fri Nov 20, 2009 10:46 am
First name: Peter
Last Name: DeWitt
City: Columbus
State: OH
Thanks, Rod. I had guessed about that.
Appreciate it.
Peter
PostPosted: Sat Nov 21, 2009 8:49 am
First name: Tom
Last Name: West
State: Nova Scotia
What is the logic of using a double UTB rather then a deeper and wider one...?
PostPosted: Sat Nov 21, 2009 9:05 am
Westca, although I do not use two UTB braces, I would think that the uppermost brace would be a good place to bolt down the fingerboard extension if you use that type of joint,, also would double as a popsicle brace?
Chuck
Users browsing this forum: Chris Ide, johnparchem and 14 guests
