It is currently Tue Aug 12, 2025 6:27 am
PostPosted: Sun Oct 04, 2009 3:26 pm
First name: Russell
Last Name: LaRoche
So a friend of mine has this guitar which is covered with 30 years worth of stickers and he wants to through a clear coat over it. The only thing I am able to spray right now is KTM-9. I'm curious to see if I would need to lay something down before spraying the KTM-9. Maybe shellac first? Not sure what the adhesion hurdle would be..? Any thoughts on how to make this possible?
Thanks...
Barron Wesley Guitars
PostPosted: Mon Oct 05, 2009 9:47 am
Last Name: Nowicki
City: Mequon
State: WI
Zip/Postal Code: 53092
Watch out, Test the shellac or whatever else you choose to use on a small area, it may dissolve the ink on the stickers.
John Nowicki
PostPosted: Mon Oct 05, 2009 1:10 pm
First name: Russell
Last Name: LaRoche
Thanks for the advice. Ya - looks like some experimenting may be needed here. I'm not sure many people have done this one before...Thanks much..
PostPosted: Tue Oct 06, 2009 12:53 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
IIRC, there's a spray (can) that artists use for pictures, collages, and the like that seals all kinds of ink prior to spraying on top varnish/lacquer coats (that dissolve ink). You might like to investigate the art world for this solution - seems like it should work nicely for what you have planned for this guitar. Shellac may not be clear enough for the customer's liking IMO.
Cheers,
Dave F.
Cambrian Guitars
Users browsing this forum: Chris Ensor, doncaparker and 17 guests
