It is currently Tue Aug 12, 2025 1:13 am
 Post subject: Pickguard Removal
PostPosted: Wed Sep 16, 2009 9:21 am
So I've finished this guitar (see the post on Steve's Walnut OM) and I don't like the pickguard I put on it so I'd like to replace it. I installed it using the adhesive sheets that StewMac sells. My first inclination is to try naptha and a small, thin, very flexible spatula to slowly work it off the top. The finish is Emtech 6000
Anybody have any recommendations or does this sound like the way to go?
 Post subject: Re: Pickguard Removal
PostPosted: Wed Sep 16, 2009 10:07 am
hair dryer or heat gun ..... warm the pickguard up a bit so you can lift one of the edges, then blow heat under the lifting edge and peel it up .. been done a few times at my shop.
PostPosted: Wed Sep 16, 2009 12:22 pm
Thanks Tony. I'll give that a try as soon as my new pickguard material arrives.
PostPosted: Wed Sep 16, 2009 12:54 pm
Btw .. any residue left on the finish can usually be taken off with some mineral spirits.
PostPosted: Wed Sep 16, 2009 3:53 pm
First name: Jonathan
Last Name: Coleman
City: Lacona
Zip/Postal Code: 13083
speaking of pick guards, Has there ever been any research done on the effect of weather or not a pick guard has any dampining effect on the guitar?? I personally dont like them and have always removed them from my guitars and maybe its just in my head but they always seem to have more sustain and overall tone.
PostPosted: Wed Sep 16, 2009 7:36 pm
First name: Celso
Last Name: Pinto
Country: Portugal
As long as you're adding mass or stiffening your top, the tone is bound to change. Whether it's good or bad, significant or insignificant, that would be a personal judgment. However, I don't like them either ;)
As for the original question, I did that earlier today with naptha and aluminum foil covering it, letting the naptha work its magic.
PostPosted: Thu Sep 17, 2009 9:58 am
Thanks Celso, I thought that might work too. I assume you just lay the aluminum foil over the pickguard area to keep the naptha from evaporating too fast?
