It is currently Mon Aug 11, 2025 1:58 pm
 Post subject: Top Waist Cut-offs Uses?
PostPosted: Tue Aug 11, 2009 5:43 pm
Last Name: Sollod
I can find uses for the cut-offs at the waist of the backs, like rosettes or head plates, but what about the cut-offs at the waist of tops? Does anyone use these pieces for anything? ...maybe side bracing or something...? I'd like to use it for something other than waste...
www.swiftcreekguitars.com
PostPosted: Tue Aug 11, 2009 5:49 pm
firewood? ;)
PostPosted: Tue Aug 11, 2009 6:03 pm
popsicle braces and soundhole reinforcements?
Save them to have matching wood for when the top needs repair?
PostPosted: Tue Aug 11, 2009 6:18 pm
Country: Romania
Defintily not waste! JM has apoint with repairs. Myself I use them to get the density for both inner and outer sections of the tree, and I save them for later reference. On the larger pieces it is possible to do some useful deflection testing. If there is no runout I can cut fan braces. If there is some runout, they are still good for soundhole and side braces.
You can also use them for back reinforcement strips.
Build log
PostPosted: Tue Aug 11, 2009 7:37 pm
First name: Tom
Last Name: West
State: Nova Scotia
Use them to widen the top from which they were cut.
PostPosted: Tue Aug 11, 2009 7:49 pm
Oops - I misread the post. I thought you asked about the backs and tops.
I keep them for repairs, small braces and for any "just in case" scenarios that come up.
Laurie
PostPosted: Tue Aug 11, 2009 8:24 pm
All of the above.
I also use the, for side reinforcement braces.
Alain Moisan
(Now building just for fun!)
PostPosted: Wed Aug 12, 2009 1:14 pm
If ever you are using waist off cuts as wings to widen a top, it is a good idea to take the piece from one plate of the book match, flip it over, and then glue it to the opposite plate from which it was originally cut. Doing so will match up any runout in the top perfectly so the wings will remain virtually undetectable once a finish goes on and light refraction comes in to play.
Edit: By Kim 12/12/11....The above paragraph is misinformed. To match grain runout with the top plate so that light refraction within a waist off cut glued on as a 'wing' remains the same, you must either take the waste from the 'same' side it had been cut from and then shoot a new jointing edge along its 'curved' edge, being that edge cut to form the waist of the top/back, or, the curved edge from the opposite plate...flipping will make no difference to runout orientation as the angle remains the same regardless of which surface you view it from.
PostPosted: Wed Aug 12, 2009 1:22 pm
Clamping cauls, cleat material, Glue removing tools the list is as long as your imagination
PostPosted: Thu Aug 13, 2009 1:27 am
PostPosted: Thu Aug 13, 2009 3:42 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I use them to make an all-side-grain middle bit for the soundhole...
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Thu Aug 13, 2009 6:44 am
Tasteful and cleverly executed Dave. [:Y:]
PostPosted: Thu Aug 13, 2009 8:51 am
I label one so I know which side, bass or treble, it came from, which end points to the neck, which guitar it came from, in case I need a patch if the customer needs a repair done to the top. The one repair I've done is pretty much invisible.
Users browsing this forum: jfrench, JimKlingshirn and 41 guests
