It is currently Mon Aug 11, 2025 4:41 pm
PostPosted: Tue Jul 28, 2009 7:27 am
Hello,
I have two very nice pre-made classical bridges (StewMac and one that was given to me) for a nylon build I'm getting close to setting up. One bridge has a compensated saddle slot and the other does not. I should also mention that this is a lattice braced nylon cross over style instrument with a 25.4" scale.
For those of you who build nylons, which would be my better choiceof saddle?
Ray
Guitar Building = Continuous Improvement Process
PostPosted: Tue Jul 28, 2009 8:01 am
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
I've never been a fan of an angled saddle slot on a nylon string. I have always used a straight saddle slot and compensate by shaving 1/2 mm from the top of the fretboard at the nut and then file the saddle to fine tune.
Peter
PostPosted: Tue Jul 28, 2009 3:01 pm
Nylon strings don't need anywhere near as much bridge compensation as steel. Nylon stretches when you push the string down on the fret, while steel just gets tighter. Usually you can get all the compensation you need on a classical by filing the top of the saddle a bit.
PostPosted: Thu Aug 06, 2009 1:40 pm
First name: Jyme
Last Name: Bale
City: Dickinson
Zip/Postal Code: 77539
The gentleman above is completely correct to a point. Most classical players have never seen really hight end classical guitars from Spain, the instruments costing $25,000 and up and take six months to build with waiting lists of three years and counting! Many of the Spainish luthiers install compensated saddles and if they do it there must be a good reason for it. I have tried in vane to contact and ask why.
I've built one classical so far and installed the regular straight across saddle.
PostPosted: Thu Aug 06, 2009 5:16 pm
Greg Byers gives a good insight into classical guitar compensation ....... http://www.byersguitars.com/Research/Research.html
Paul Jacobson has arrived at a similar conclusion, albeit with slightly different compensation values http://www.pjguitar.com/website/forums/ ... ation.html
Happy reading !! ;)
http://www.reesguitars.co.uk
PostPosted: Thu Aug 06, 2009 7:34 pm
First name: David
Last Name: LaPlante
Hello Stephen!
Nice to see you in these pages.
This time of year I can't help but think of what a nice experience Spain was.
Hope all is well with you.
Best
David
www.guitarsbydavidlaplante.com
PostPosted: Thu Aug 06, 2009 10:38 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Hey Peter, fantastic photo of your "compensated by filing" saddle - thanks for sharing!
Rob
PostPosted: Fri Aug 07, 2009 3:41 am
David LaPlante wrote:
Hello Stephen!
Hi David,
Yes, I must admit I do miss the annual pilgrimage to Sigüenza ..... mind you, trying to keep an eye on 20 or so guitarmakers at all hours of the day & night for 2 weeks solid is pretty exhausting!! .... wouldn't have missed it for the world though, and would be happy to go straight back tomorrow !!
I trust all is well with you?
All the best,
Users browsing this forum: TripodBob and 41 guests
