It is currently Thu Aug 14, 2025 10:00 am
 Post subject: Tie Block Inlay
PostPosted: Wed Jul 01, 2009 4:13 pm
Last Name: Nowicki
City: Mequon
State: WI
Zip/Postal Code: 53092
Hello all,
Am building a Negra flamenco and want to use black buffalo horn for the nut, saddle and tie block inlay. Should look good with Black MOP buttons on the tuners. I machined the nut and saddle on a CNC. Works out pretty sweet. My question is how can I cut my buffalo horn stock into strips suitable for use as Tie block inlay strips (2mm x 2mm x 72mm or so)? I might try a fence on a band saw after reading some other posts. Or if anyones knows of a source of black bone (or other matching material) strips in a suitable size for same let me know. The center of the inlay will be ebony with some multi line purfling between the ebony and the horn. Thanks for the help! I appreciate all of the artfull knowledge here.
John Nowicki
 Post subject: Re: Tie Block Inlay
PostPosted: Thu Jul 02, 2009 8:56 am
Country: Romania
I cut my tieblock strips from thin saddle blanks using a Japanese saw. A coping saw should work too I imagine. LMI sells black horn saddle blanks, only that they are 3.9mm thick so you still have lots of sanding to do.
Build log
PostPosted: Thu Jul 02, 2009 5:41 pm
Last Name: Nowicki
City: Mequon
State: WI
Thanks , I will use the Japenese saw. As usual there is no easier way. I think Black horn Tie Block inlay will look cool........
John Nowicki
PostPosted: Thu Jul 02, 2009 6:53 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
I've used it. It does look cool. Very cool.
Pretty sure that I used my bandsaw...
Actually, I think that I used ebony for the tie block.
http://redrivercanoe.ca/
Users browsing this forum: Michaeldc and 14 guests
