It is currently Wed Aug 13, 2025 5:04 pm
PostPosted: Sat Jun 27, 2009 10:08 pm
Any experience out there dissassembling the neck joint on this old guitar? One came into the shop needing a neck reset.
Any wisdom gained through experience would be appreciated!
PostPosted: Sun Jun 28, 2009 6:24 pm
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
Steve,
The neck joint should be a short dovetail. I reset one of these a while back and that's what I found. It was a thin body 125. The neck I did was loose in the joint when I got it. I popped it by running hot water into the joint around the fingerboard extension and wiggling the body until it dropped out.
Louis
- Louis Freilicher
PostPosted: Sun Jun 28, 2009 9:45 pm
Hey Louis, thanks!
Yes, that's what I was hoping for.
So you didn't have to pump steam into the 15th fret slot, etc?
This is also a thin body, in fact the label says it's a 125-T, which I assume means "thin".
Thanks for the report!
PostPosted: Sun Jun 28, 2009 10:07 pm
First name: Louis
City: Belchertown
State: MA
Steve,
I didn't use steam in this case because the joint was already broken and I had decent access. The dovetails had split so that the neck shaft was moving but still held captive in the mortise, the outer edges of the dovetail were still glued to the block. Just dripping some hot water in there was enough to get it apart. I have use this method a few times where I did not want to introduce steam to the neck shaft / fingerboard extension joint on mandolins and archtop guitars.
Louis
- Louis Freilicher
PostPosted: Mon Jun 29, 2009 2:17 pm
Thanks Louis!
Sent you a PM by the way.
PostPosted: Mon Jun 29, 2009 5:50 pm
Steve,
The traditional repair technique for these is a couple of woodscrews through the heel.
Unfortunately mine is so aflicted (not by me)
PostPosted: Mon Jun 29, 2009 10:18 pm
Don't tempt me like that!
Users browsing this forum: DennisK, James Orr and 44 guests
