It is currently Mon Aug 11, 2025 5:01 am
 Post subject: Got CA Solvent?
PostPosted: Tue Jun 23, 2009 9:12 am
So about three years ago I bought a bottle of CA solvent and stuck it on the shelf. Never used it, never needed it then...................
Last night I glued two fingers together, really did a good job too idunno
That solvent came in real handy. :oops:
If you don't have any you might want to get some. I guess acetone would do good too.
 Post subject: Re: Got CA Solvent?
PostPosted: Tue Jun 23, 2009 10:29 am
Steve,
Thank you for the info. Do you know any solvent for contact glue (adhesive).
I would like to clean my sanding board to glue another sheet of sanding paper and it is taking tooo long [headinwall]
PostPosted: Tue Jun 23, 2009 11:31 am
Antonio wrote:
Steve,
Have you tried naptha? That usually works for sticky-backed sandpaper, otherwise maybe someone else has an idea.
PostPosted: Tue Jun 23, 2009 11:41 am
They use lighter fluid at the bookshop to remove old price stickers and residue from used books.
PostPosted: Tue Jun 23, 2009 12:20 pm
Good point, lighter fluid and Naptha are the same thing.
PostPosted: Tue Jun 23, 2009 12:37 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Some lighter fluids are no longer naptha based. Naptha is sometimes spelled Naphtha. It's the same thing. You can buy a big bottle of naptha(or naphtha) at a hardware store for the price of a small bottle of lighter fluid. Obviously it's extrememly flammable so be careful.
I was told the CA "debonder" is a mixture of acetone and cooking oil. I just keep some acetone handy. I have a tendency to glue.........everything to...........everything.
FWIW, I don't think Naptha will work on CA, but it works great for most adhesives.
PostPosted: Tue Jun 23, 2009 1:52 pm
I didn't know that, I have a can of lighter fluid at work I've had for probably 10 years.
PostPosted: Tue Jun 23, 2009 2:48 pm
First name: Nelson
Last Name: Palen
Confucius say: He who spills CA on floor best not work barefoot.
PostPosted: Tue Jun 23, 2009 3:45 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I thought fingernail polish and acetone (same thing?) were good solvents for CA. BTW, gluing your fingers together is a neat trick right before the big games on Saturday which normally coincide with the Honey-Do list being handed over. You can still hold a long neck bottle too. 8-)
PostPosted: Tue Jun 23, 2009 3:56 pm
Last Name: Shannon
City: Milford
State: OH
Have you tried "Goo gone" ? Pretty easy to find and it's worked well for me in removing some pretty tenacious adhesives.
PostPosted: Tue Jun 23, 2009 4:22 pm
I may have to try that one.
PostPosted: Tue Jun 23, 2009 4:59 pm
Fingernail polish remover WITH acetone in it. They make some acetone free brands, and it won't work on CA. It's the acetone that dissolves the glue. Don't ask how I found that little tid-bit out....
Rob
PostPosted: Wed Jun 24, 2009 12:58 am
Last Name: Garrish
She.
Bob Garrish
PostPosted: Wed Jun 24, 2009 10:10 am
If you glue two fingers together with CA glue take a Bic pen or similar(octagonal shaped body) and roll it through the two fingers from the inside to the out. Bingo , no pain, nothing, instant release. Try it and see. It also makes a good party trick.
Cheers Chopper
PostPosted: Wed Jun 24, 2009 10:27 am
Cheers Chopper
That would work good for two finger tips. Not so good for side to side which is what I did. :)
Users browsing this forum: No registered users and 45 guests
