It is currently Tue Aug 12, 2025 12:53 am
 Post subject: 14th Hump/Dive
PostPosted: Wed Jun 17, 2009 7:19 pm
Guys I'm close to finishing my second instrument now, 1 guitar, 1 Uke, and I've used bolt-on necks, after fretting on both the tongue on bolting to the body there is always this fall away I assume its created when the frets are hammered in and the upper end of the fingerboard expands. What are the ways to avoid this and get a good fret job?
Formerly JJH
 Post subject: Re: 14th Hump/Dive
PostPosted: Wed Jun 17, 2009 8:58 pm
First name: David
Last Name: Engel
City: Stanwood
Hi John,
Exact same thing happened to me. What I suspected (as I was doing it [headinwall] ) was the fret slots were to tight and I was having to hammer in to hard. Sure enough, next guitar widened the slots slightly, Elmers glue and frets went it very smoothly with NO board warping at all.
Frets do NOT need to be installed so flippin tight! They got tangs and some Elmers (some even use epoxy). They are not going anywhere!
Give it a try.
God, Family, Carreer
PostPosted: Wed Jun 17, 2009 9:05 pm
If you are installing the frets off the next, then you can help set them by supporting the fretboard at the ends and use a clamp in the middle to pull it down into a gentle U. This forces most of the fret barbs into the wood. It's not a perfect solution, but it goes a long way to avoiding the bowing caused by having too narrow kerfs.
Users browsing this forum: No registered users and 50 guests
