It is currently Mon Aug 11, 2025 2:21 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 21, 2009 10:01 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I get them close with a jointer. Then I put them between 2 pieces of 3/4" plywood clamped to my bench and use a 24" level with 120 grit adhesive sandpaper on the edge of the level.
PostPosted: Thu May 21, 2009 10:58 pm
Thanks Pat. That makes sense.
PostPosted: Fri May 22, 2009 8:49 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Chris Paulick wrote:
Well, After gathering some of your ideas I broke down and whipped on together today with parts I had laying around the shop. It has a front hook that hangs under the front that also butts against my vise or I can secure it in the vise too. The back fence is adjustable. I had a piece of track left over from my router table. I figure it can be used as a bench hook too and I can make a 45 degree piece that can bolt down to the track too for miters. I could probably slide the fence up and put some wet stones there to . Made from Malamine.
Very nice, and well worth the wait, I'm sure!
I've been using a jointer. The most important element in getting a jointer to provide good results is practice. Then more practice.
If I ever feel the need to make a shooting board, its going to look a lot like this one.
http://redrivercanoe.ca/
PostPosted: Fri May 22, 2009 10:22 am
Looks good Chris [:Y:] I like the use of the aluminum channel to adjust for your back stop.
Link
PostPosted: Fri May 22, 2009 4:44 pm
Link, there's no Aluminum in it unless you are talking about the T track. Here's some add-ons I did today
A spring loaded cam clamp. And a grove cut in the hook so I can hang it on the wall off of a cleat.
PostPosted: Fri May 22, 2009 8:10 pm
I was talking about the track.
L.
PostPosted: Fri May 22, 2009 8:22 pm
Chris that is way too cool, i thought you would be back here in record time with some awesome thing to post, you don't disappoint!
Jordan Aceto
Ithaca, NY
PostPosted: Fri May 22, 2009 11:08 pm
Someone on another forum ask about the construction of the cam. I made the cam using a barrel nut like I use in the adjustable neck for the pivot and capped the outside with walnut dowel plugs to keep the side movement down. here's a close up of it. and I changed the wing nuts to wood knobs like on my centerline finder. And hung it on the wall. I think the wood knobs make it look a little more craftsmans like. It's my new shop wall hanging. :)
PostPosted: Fri May 22, 2009 11:35 pm
Last Name: Killin
Very Cool Chris. I may be working on some sort of shooting board this weekend if I can get around to it.
Nice job. And timely post.
PostPosted: Sat May 23, 2009 8:55 am
Nice one Chris .. I was going to say that without a lock down of some type, you may run into tops that wont register properly against your backing fence ... for instance, I have red and italian tops that have the edge grain angle as the outside edge .. one piece is slightly narrower than the other, so there is no way to align them on the back edge .. they ahve to be clamped somehow. my shooting board is a simple piece of mdf with a lockdown clamp similar to yours, mine uses 1/4-20 inserts and a couple screws ...
PostPosted: Sat May 23, 2009 10:31 am
Thanks Tony,
Sounds like something simular to the Cumpiano Board. I've been trying to figure out where I saw the cam clamp idea before. It was either on some machine I worked with before or maybe even a WorkMate bench or maybe just exposure to jigs and tooling over time. Someone mentioned the time to remove clamps and that got me to thinking. At first I thought about using quick action toggle clamps and then looked at my cam clamp and thought about how simple of an idea that was and quick. And I like that vintage old time woodworking thing . It might sound silly but I like it when a jig comes out looking good as well as doing the job. It takes just as long to make a crapy looking tool as it does a good looking tool. Well maybe a little longer for the good looking one because I always like to soften all my edges and corners from burrs and who knows. It might save a ding on something. Although I have soften the edges on this too after the first pictures were posted.
PostPosted: Mon May 25, 2009 10:37 pm
Man what a difference a flat/ level sole and a razor sharp blade in a #5 Sweetheart Stanley and a nice board makes. Did a set of Red Spruce plates in about a minute with hardly any wood taken off. Sweet.
