It is currently Mon Aug 11, 2025 12:20 pm
PostPosted: Thu May 21, 2009 11:45 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I got to thinking about this today. Cutting the ends of the sides at the neck block and tail block is a basic activity. At least so I thought. So is it? Just exactly how do you go about it? I cut my sides proud, bend, then trim using the mold as a guide. What do you do?
PostPosted: Fri May 22, 2009 12:20 am
Table saw on the miter fence. I leave the top edge flat, that way the tail and head block ends are just squared up. I then shape the back edge with a side template. Register off the tail end when bending. Put them in the mold and I'm good to glue on the blocks and liners after a bit of a sand.
PostPosted: Fri May 22, 2009 7:15 am
I've been doing mine similiar to you Mike. Bend a little proud, put in the mold and mark the ends. Then use a square to mark the cut line, clamp the side down using a block aligned with the line. Use the block as a fence to cut with a fine toothed saw.
That said, cutting it on the table saw like Rod does would be much quicker.
PostPosted: Fri May 22, 2009 8:27 am
First name: Martin
Last Name: Edwards
bend & clamp into 2 halves of mould then usd bandsaw to trim square.
tail wedge done later
PostPosted: Fri May 22, 2009 8:47 am
I use to use a table saw until it blew out the corner of a side. I use a razor saw, two clamps and a block of wood as a stright edge.
Quick and controlled. Oh and safe [:Y:]
PostPosted: Fri May 22, 2009 8:48 am
I have cut on the table saw after bending, and cut by hand after bending. The last set I cut by hand just proud of the center line on the mold and trimmed flush on a bench hook with a plane. That was the best - low stress, nice fit.
Gabriel Regalbuto
Carlsbad, California
Freedom 35!
PostPosted: Fri May 22, 2009 9:48 am
Leave em long. Mark from mold. Transfer to inside with square. Take to bandsaw and trim. Don't get much easier, and simple.....if it wasn't I'd be lost!
PostPosted: Fri May 22, 2009 10:06 am
As long as the piece is supported on both sides of the blade with the miter fence, you should never have this problem.
PostPosted: Fri May 22, 2009 10:10 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Once determine which side is to be flat, I use joiner for that edge (I don't have any shooting boards never have), draw profile and cut out sid and then bend. Depending on mood or what going on I then do like John or use razor saw like Lance.
Last edited by stan thomison on Fri May 22, 2009 10:13 am, edited 1 time in total.
PostPosted: Fri May 22, 2009 10:12 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, OK there. Sounds like what I am doing (micro saw) and now I will add the bench hook. The table saw seems a bit frightening with chip outs and all, but properly supported as Rod said, it should be no problem.
But the bench hook really sounds like a great idea!
PostPosted: Fri May 22, 2009 10:15 am
Yes for sure! Rod is correct here! I am a bit lazy and got in to a habit of just walking to the saw and buzzing it off. The razor saw talkes me just a few minutes longer and forces me to NOT be lazy ;)
Rod, just so you know, I didnt mean to come off like I was diss'in ya bro [:Y:]
PostPosted: Fri May 22, 2009 11:08 am
Never once felt that way Lance :)
PostPosted: Fri May 22, 2009 12:02 pm
Bend long, mark length in the mold. Make sure the bandsaw blade is square to the table and with bent side top edge against the table just touch against the sawblade. I stand on the backside of the bandsaw and just clip it right off. Fast, simple and square.
Joe
PostPosted: Fri May 22, 2009 12:26 pm
I mark my sides on the mold I am using. Allow about a total of 1/8 per end. I want to have the sets tight in the mold. I like to see the waist lift off the side of the mold just as I am closing the mold. About a 1/8" lift per sides seems perfect . The spreaders will make the side set conform to the mold nicely .
When cutting the sides I like to do both at the same time using a backer to push through the blade. That way any difference on one side is corrected to the other. If you over trim you set you can always open it a tad at the tail .
PostPosted: Fri May 22, 2009 12:38 pm
I put each side in the mold seperately, using turnbuckles to push it in tightly, and mark the ends to the centerline of the mold with a knife point. Then I take the side out, and scribe across the mark perpendicular to the top edge, which is flat at this point. I've been using the knife to cut across the side on both surfaces of late, guiding with the square, and when I've got good deep cuts on both sides, the end just snaps off pretty cleanly. A couple of strokes with a block plane wil take off any spoor.
PostPosted: Fri May 22, 2009 2:59 pm
I use a my fret saw with a block clamped down as a guide. Nice clean cut.
PostPosted: Fri May 22, 2009 4:27 pm
I leave mine long, mark to length with a square and cut on bandsaw.....I too had a side chip when cutting on the tablesaw, don't do that any more. I've actually cut a bunch by hand but the bandsaw works great.
Gwaltney Guitars
PostPosted: Sat May 23, 2009 3:19 pm
I don't use an endgraft so have to get the joint bang on theoretically. I do it like David Hurd. I cut them on my miter saw leaving a 1/16" or so. I then clamp them tight, back to back and sand to a squared line using my beltsander. Any slight angling is cancelled out by doing them both at once.
PostPosted: Sun May 24, 2009 7:33 pm
Online
Bend a little long, mark correct length using mold, cut quite close with the bandsaw, true up on the edge sander.
PostPosted: Sun May 24, 2009 9:51 pm
That's exactly what I do.
TJK
PostPosted: Sun May 24, 2009 10:51 pm
First name: Chuck
Last Name: Hutchison
City: Houston
I've been using one of these for making a clean cut without nicking out big chunks on the sides. Works rather well in "stun wood" mode.
Users browsing this forum: Freeman, jfrench, meddlingfool and 48 guests
