It is currently Tue Aug 12, 2025 1:10 am
PostPosted: Thu May 07, 2009 12:41 pm
Last Name: Cox
Hey all,
Got a couple questions -- I want to try building a "Real" Nick Lucas special sort of guitar....
Reading the dimensions of the old ones -- 1926-ish... they look similar in size to the Gibson L-0 dimensions.... like 13 1/2" across the lower bout size...
I took a look at the 1920 L-0 prints, and they are kinda like a modified A-brace/ladder brace design... Not an X brace.
So... for folks who have fooled around with the old "real" Nick Lucas', What is in there? Would following the old 1920's L-0 print for the modified A-bracing and short neck and building body deeper give a sound that is similar to the originals.... or is this too weak, and why Gibson departed from this design by the early 30's?
PostPosted: Thu May 07, 2009 2:47 pm
The "old style" Nicks were either H or A braced, generally, but like everything Gibson, an X-braced one has surfaced.
Yes, they were deeper L-1's, with a "slightly convex" top and back.
But the build was more refined, cosmetically and functionally.
The challenge (to me) of an old-style Nick reproduction is to give it that visual quality, but to make it NOT sound like a stump with a neck to match.
PostPosted: Sun May 10, 2009 6:29 pm
Last Name: Cox
So... should I go for the H/A bracing pattern, or the more modern X pattern?
I am sure the H pattern may sound more "Authentic" -- if i can get it right.... But... I think there is probably a reason we only see the X braced models today.... Even the old ones seem to have been converted into X braced models sometimes in their lives.
PostPosted: Mon May 11, 2009 8:22 am
John,
Since you asked the question, and I'm your audience (I currently have a "later" NLS in the works) I think you should use the bracing that you are comfortable with.
I would adapt the X bracing that I understand to the guitar at hand.
I once did a ladder braced guitar that a customer wanted, and did not find much joy in the process. Call me a one-trick-pony, but maybe I know my one trick really well.
If the "H" bracing has any value, it is unknown to us today.
If you want to do a period correct reproduction (I'm a history buff as much as anyone) you are sure to find some interest in it.
PostPosted: Mon May 11, 2009 10:08 am
John,
I've just built my first L-0 inspired guitar. I built a 12 fret version and opted to go with x-bracing: coco/sitka. It's an experiment, that's for sure. I still haven't strung it up. I'm waiting for the varnish to cure before buffing. But I'll let you know how it sounds when it's all put together.
Best,
Flori
