It is currently Sun Aug 10, 2025 1:05 am
 Post subject: Martin truss Rod wrench
PostPosted: Sat Apr 25, 2009 6:56 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
i`d like to take some relief out of a Martin that is only a couple of years old.I`m not sure what kind of wrench or whatever I need .
James
James W Bolan
Nashville Tennessee
PostPosted: Sat Apr 25, 2009 11:56 pm
Here you go.
PostPosted: Sun Apr 26, 2009 1:19 am
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Always one in every crowd. laughing6-hehe
This is what I use, it's a 3/16 allen key.
Cal
PostPosted: Sun Apr 26, 2009 8:46 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Thanks cal,I wasn`t sure if I needed 5 mm or 3/16.Don`t want to wreck anything.I really like Kyle`s wrench a littlle better.Seems like the way I usually go at things.Kyle you must have seen my chain saw technique in my avatar for carving necks.
James
James W Bolan
Nashville Tennessee
PostPosted: Sun Apr 26, 2009 6:41 pm
I just adjusted an HD28 this afternoon. 5mm was the correct size for this guitar, 3/16" would be too loose. I recommend you remove the nut and lubricate it before adjusting as most are not lubricated at the factory. I use a tiny dab of graphite wheel bearing grease on the threads but a drop of oil will work as well.
If you want to know more about truss rods, Frank Ford has good info at Frets.com.
http://www.frets.com/FRETSPages/Musician/GenSetup/TrussRods/TrussRodAdj/tradj.html
PostPosted: Sun Apr 26, 2009 9:42 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
What`s the procedure for removing the nut?
James
James W Bolan
Nashville Tennessee
PostPosted: Sun Apr 26, 2009 10:29 pm
If it's a single action rod (probably) just keep turning to the left and catch it when it falls out. A few refuse to fall but can be coaxed out with needle nosed pliers.
If it's a double action rod (the adjustment nut will be right above the neck block) I suppose you could then make use of Kyle's wrench. :D
Just kidding - I haven't had occasion to remove one of those (yet).
Jay
PostPosted: Mon Apr 27, 2009 8:08 am
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Oops! :oops: I stand corrected. That allen key is 5mm. not 3/16.
Cal
Users browsing this forum: Bing [Bot] and 41 guests
