It is currently Thu Aug 07, 2025 7:48 am
 Post subject: Compromises
PostPosted: Tue Apr 14, 2009 6:28 pm
Compromises, do you make them and what do you consider an allowable compromise, I mean as in finish durability over tone, top thickness, bracing, weight, time etc.
Do you make them? If so where do you feel they're acceptable, I love Ervin Somogyis phrase "building on the cusp of disaster" that sums it up for me
Formerly JJH
 Post subject: Re: Compromises
PostPosted: Tue Apr 14, 2009 8:17 pm
To build on the cusp of disaster in its self implies compromise. Anyone that says that they don't compromise are not reasoning their way forward but rather stumbling their way along . For it is impossible to make a knowledgeable decision with some degree of compromise. like all things, Lutherie is a constant compromise at every task in the process. From sellecting wood to struming the first chord on the instrument.
PostPosted: Tue Apr 14, 2009 9:12 pm
Amen...
Rich S
"The inconvenience of poor quality will linger long after the thrill of a bargain has been forgotten"
PostPosted: Tue Apr 14, 2009 10:39 pm
I look at it this way.
The first stage to becoming a good builder is acquiring a certain level of knowledge. Not that you ever stop learning, but you need to acquire a core level.
The second stage is acquiring a certain level of skill, which is to say, effectively applying that knowledge. Again, not that you ever stop improving your skills, but you need to reach a certain level.
The third stage has to do with the decisions that you make (reminds me of a Harry Potter book). Everyone makes compromises, but as you progress your standards are raised and things that were maybe once acceptable are no longer acceptable. This may mean a lot rework or starting over, but that is how it is.
Randy Muth
RS Muth Guitars Website
RS Muth Guitars Blog
Facebook Fan Page
PostPosted: Wed Apr 15, 2009 12:37 pm
There are compromises and compromises.
On the one hand, as has been pointed out, the whole design of the guitar is a matter of compromises, or as I prefer it, balance. Do you make the top strong enough to hold up forever under all sorts of punishment, or light enough to be responsive? Do you give up some treble response to get better bass? How about volume vs sustain? You may or may not think of any of these as compromises, but they are all things that people want, and you do have to give up some to get others (usually). The best policy here is, I think, to set out the options and let the customer, if there is one, decide.
Thus, for your example of finsh durabilty vs tone: the two finishes I use are French polish and Behlen's 'Rockhard' varnish. FP is probably tonally a better choice, but it is less durable, if only because there's less of it, and it has less chmical resistance. The varnish is also a little prettier, IMO. The lead time for FP is less than that for varnish, although both take about the same number of hours to do.
Most of the time classical guitarists would prefer the FP, at least on the top, simply because the margins for tone are so slim on a classical. You really have to keep the weight and damping down on a clssaicl top to get the best tone, and there's no lighter finish than FP, nr any with much lower damping. In this chioce they accept the fact that the top will not put up with much abuse.
In most cases I'll tend to steer steel string customers toward varnish. The added durability is useful in instruments that are often not as pampered as classicals. Also, the cost in sound is less.
The more difficult type of compromise to justify is when you do something that is less than the best you can do. The fact is that, in spite of all protestations, we can't always be at our best. Stuff happens. You run out of what you consider the 'best' sort of liner stock just when you don't have time to make or order more, so you use what you have on hand. Maybe the router adjustment wasn't as tight as it should have been, and the binding channel ends up being wider than you wanted it to be. Do you toss the box? That would be the 'no comprmise' solution, but how many of us can afford to do that? In these cases you have to ask yourself how serious the compromise is. Maybe you prefer reverse kerf cedar liners just because you find it easier to do the inlets neatly, but, in reality, you can't pint to any other problem they would cause. That's not the sort of 'compromise' I'd lose any sleep over. Using a screw on plastic Gibson bridge with the heavy metal height adjuster, because I had it handy, of to avoid bothering to get the neck set right, is not an acceptible compromise, IMO.
I can say with some confidence that if I only allowed the 'perfect' guitars out of my shop you'd never see on with my name on it. No matter how good I get, I know there's always something I can do better. In that sense, then, every instrument I sell compromises my reputation in some way.
The one thing you can't compromise on is the effort to get at least a little better every time. Part of that is learning what 'better' is: you don't know what you don't know, and can't be blamed for doing something you didn't know was a problem. All you can do is the best you know how, and always try to do better. Then, IMO, you're not 'compromising' anything.
PostPosted: Wed Apr 15, 2009 12:58 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
said so well Alan !!
Instrument making is the toughest woodworking venture there is!
Our instruments get treated like the tools their meant to be .
Mike Collins
PostPosted: Wed Apr 15, 2009 1:26 pm
Grit Laskin once said .. "the next one will be BETTER".
Nuff said.
PostPosted: Wed Apr 15, 2009 1:34 pm
First name: Corky
Last Name: Long
City: Mount Kisco
I can offer the perspective of a novice - having just finished my fourth steel string.
I've learned volumes about myself and about patience in pursuing this wonderful obsession, in just the short two years since I've discovered I love to build guitars.
For me, the compromises started early, although they were less about conscious decisions to make tradeoffs of quality versus efficiency, as I'm sure many of you pros live and struggle with on a daily basis. No, for me the compromises were more about - "Do I start with totally fresh neck stock after my router went through the beck of the neck gaah , or do I chalk it up to a learning experience and find a way to repair it" -
I've made a lot of mistakes in building these guitars, [headinwall] and have had to start over in some cases, in others, did the best I could with the lemons (and my own inexperience).
But at the end of the day, these compromises and learning to live with and recover from the errors has been almost as gratifying as putting those strings on for the first time. Now, when I make the same mistake twice..... it's a bit of a different story..... wow7-eyes
PostPosted: Wed Apr 15, 2009 4:14 pm
The day I build the perfect guitar is the day I'll quit. Ain't gonna happen.
Randy Muth
Facebook Fan Page
Users browsing this forum: zmp2 and 43 guests
cron
