It is currently Thu Aug 07, 2025 12:15 pm
PostPosted: Tue Apr 07, 2009 5:28 pm
This one seems a fair bit off quartersawn - useable or no?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Tue Apr 07, 2009 5:53 pm
I take it thats a one piece blank, requiring a scarf headstock and add on heel block ???
when purchasing large mahogany boards, you never get perfectly quartered (or flat) grain across say 12 or 14 wide timber ... some blanks will have rift sawn grain. If you want to make that more stable you could always rip in half and flip one piece, glue it back togther. While you are at it, add an accent line in there. You will see all kinds of factory guitars with neck stock like that. If its properly dried and seasoned, it will be fine IMO.
personally, I wouldnt have an issue with it.
PostPosted: Tue Apr 07, 2009 5:57 pm
Tony, OK I may do as you say. I've been spoiled - having got well quartered neck wood. This time I thought I would try one of the sponsors and got this piece.
Rich Smith
Issaquah, WA
PostPosted: Tue Apr 07, 2009 9:07 pm
I would also use it.
Alain Moisan
(Now building just for fun!)
PostPosted: Tue Apr 07, 2009 10:01 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I asked Warmoth about flatsawn mahogany necks they said they could only get honduran mahogany in flatsawn these days and they use it all the time. So I guess it should work.
Typhoon Guitars
PostPosted: Wed Apr 08, 2009 8:11 pm
First name: Patrick
Last Name: Hanna
State: Missouri
What Tony said. I once bought a mahogany blank with grain oriented exactly like your blank. I ripped it down the center, flipped one piece end for end, re-glued it with the grain orientations offsetting each other in either half, and built the neck. Fifteen years later, no problems whatsoever. (At least with the neck!)
PostPosted: Wed Apr 08, 2009 8:53 pm
Another thing to look for in neck blanks like that is the grain fairly consistent down the neck or is it changing a lot. Resawing and flipping is the way to handle it for sure.
PostPosted: Wed Apr 08, 2009 9:26 pm
Last Name: Hodge
What Tony, cphanna, and Jim said!
I'd make it a 3 or 5 piece neck. Makes for a really cool looking and stable neck. ;)
Bill Hodge
PostPosted: Thu Apr 09, 2009 9:13 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Ricardo,
Are you using this for your classical? If so, I'm sure that you'll be fine using it as is. If in real doubt, then rip in half and balance the grain.
Using a multi-piece laminate is often seen in steel string guitars but not so much with classicals. Actually, I've never seen it, and it would raise many eyebrows.
What is seen from time to time is a dark hardwood strip laminated in the center, like many Ramirez guitars, including the 1a. If you do this no one will ever know that you did it to flip the grain.
http://redrivercanoe.ca/
PostPosted: Thu Apr 09, 2009 9:31 am
Country: Romania
Looks OK to me. If you visualize what is left of it in the end product, it might even be perfect since the center looks nicely quartered. Of the cedrella necks i bought so far, all have been slightly skewed so i simply gave up hope on getting really quartered wood.
As Doug said too, for a classical you can use a (not too wide) strip of ebony or rosewood in the center. I've seen necks that also had thin "purfling" lines flanking the strip and I don't like it. Keep it simple looking.
Build log
PostPosted: Thu Apr 09, 2009 10:21 am
Alexandru & al, I went with it. I think it will turn out fine. Thanks for all the input and good ideas!
Rich Smith
Issaquah, WA
PostPosted: Thu Apr 09, 2009 11:24 am
Ricardo, That board is a tough call for me, if the other end looks the same and the grain is straight throughout I might go with it as is.
If you decide to flip you might consider a technique that uses three pieces of wood. I learned this from a 2001 post by David Schramm where he explains a method taught to him by John Gilbert:
Link to classical neck post ---scroll down through the post.
It's a standard flip with a thin piece of quartered laminated in the middle. You get a stable strong neck out of a marginal piece of wood, but with the drawback of a noticeable line down the middle of the neck.
PostPosted: Thu Apr 09, 2009 1:04 pm
I have seen a number of classicals with multi-piece necks. I don't think it's Taboo!
PostPosted: Thu Apr 09, 2009 1:36 pm
Thanks Marc, Waddy et al. My neck will be thinner than normal for a CG since I will have a nut width of 1 7/8. I will put in a truss rod to add some mass and hopefully keep the proper relief.
Rich Smith
Issaquah, WA
Users browsing this forum: doncaparker and 39 guests
