It is currently Thu Aug 07, 2025 5:54 pm
PostPosted: Tue Apr 07, 2009 12:35 am
Have just finished this one from Tasmanian Blackwood and King William Pine.
The bindings are ebony, the fingerboard is some curly Blackwood and the neck and bridge are also made from Blackwood.
This one is a departure from our normal builds in that the sides are laminated.
Two sets of blackwood were bent and then glued with Titebond. Both side sets were bent at .080 so the total thickness of the sides is a bit over .160. It doesn't add a heap to the weight of the guitar as the blackwood is quite light.
It certainly seems to have made a difference to the sound of this instrument. It projects extremely well ie it's loud, and has strong presence in the mids. It's certainly encouraging enough to try double sides on a few more.
Here's some pics of the sides.
Bob Connor
Geelong, Australia
PostPosted: Tue Apr 07, 2009 8:11 am
Looks great, Bob! [:Y:] [:Y:] Nicely appointed but not "blingy". I like it a lot.
Finish?
How do you think the pine changed the tone?
PostPosted: Tue Apr 07, 2009 8:54 am
Just gorgeous...the figure on the blackwood is just mouth-watering.
PostPosted: Tue Apr 07, 2009 12:08 pm
City: Escondido
Zip/Postal Code: 92029
Blackwood is expensive here in California. I am not sure I could afford to double up on the sides. However, it makes me think of using a thin hard to bend side laminated to an easier to bend and less expensive wood. Anyone have any experience with that? Would the different woods laminated together cause a stability problem (I doesn't seem likely given that plywood is just that, but you never know).
PostPosted: Tue Apr 07, 2009 12:37 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Beautiful gitar!!!
The blue purfs. are neet!
Did you make them?
Any pics of the top bracings?
Is the Pine available to others ?
Mike Collins
PostPosted: Tue Apr 07, 2009 1:34 pm
Stunning!! [clap] [clap] [clap]
PostPosted: Tue Apr 07, 2009 3:17 pm
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
Mike Collins wrote:
Beautiful gitar!!!
Did you make them?
You can get some King William Pine from Tim Spittle at Australian Tone Woods. He's got some in the mail to me right now.
I also got to see and hear this guitar of Bob's last month. It's every thing he says it is. Projection, volume and note clarity is quite astonishing. It's a really lovely little guitar.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Tue Apr 07, 2009 5:13 pm
That is a striking guitar. Very tastefully executed.
I am really curious about the King William Pine. Who sells that?
PostPosted: Tue Apr 07, 2009 6:08 pm
thats a warm brown guitar, ebony bindings and end graft work great.
any sound clips?
best wishes
Geordie
some tunes on acoustic and guitar synth.
http://www.youtube.com/user/TheGeordieAdams
http://www.myspace.com/geordieadams
PostPosted: Tue Apr 07, 2009 9:47 pm
Really nice guitar Bob, you must be very proud!!!
Terence
www.guitarbench.com
PostPosted: Tue Apr 07, 2009 10:08 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I saw some acacia type wood from Taiwan at a supplier one time, I took some water to it to see the figure and it looks so beautiful but the price is only 1/10th of Koa. It looks just like Koa too.
Typhoon Guitars
PostPosted: Wed Apr 08, 2009 5:27 am
Thanks very much for the kind words folks.
Pat - the finish is Mirotone 3220 which is an Australian produced pre-catalysed lacquer. The local guitar factory, Maton use the satin version on some of their instruments
As far as the sound of it I'm not sure yet. I need to build some more with it. This is the second, both of them being 0 models with Blackwood back and sides and they sound like cheese and chalk.
The first one had the top thicknessed to 2.75mm and is a very sweet sounding instrument, reasonably balanced but if anything lacking in the top end.
The second one (this one) has the top at 3mm and has much more mid and top end presence(and much more projection). So I'm not sure whether it is the thickness of the top or the fact that this one has very thick laminated sides. I need to do some more work with this before coming to any conclusions. Suffice to say I'm keen to do more laminated sides after hearing this instrument. I don't think the way that I voice tops has changed that much in 12 months.
Mike - the purflings came from Gurian. They are fibre, which I'm a little suss about at present. They seem to swell under finish and some months down the track leave small ridges in the finish. (others here in Australia are reporting the same thing) So my next order will be dyed wood as opposed to the fibre. The jury's still out on that 'til I try the wood ones.
The top bracing is very standard Martin scallops but I do forward shift the braces to try and give these little fellas some more bottom end. Unfortunately I don't have any pics.
King Billy is available through Tim Spittle at Australian Acoustic Tonewoods but it is difficult to source decent sets any more. It is protected and no longer logged so we have to use what gets scavenged from the forest floor or from rivers and lakes.
It is incredibly slow growing and they can take a few thousand years to reach maturity.
It's actually not a pine and is closer to a Redwood than anything else.
Properties-wise it probably sits in between Cedar and Engelmann as far as hardness and is never that stiff, particularly cross grain, so I don't reckon it's any good for larger guitars.
John K - I sent your bro a set of this last year and he tells me he'll be building with it toward the end of this year. So I'm keen to hear his thoughts after he's worked with it.
Geordie - no sound clips yet. I'll try though.
Bob Connor
Geelong, Australia
PostPosted: Wed Apr 08, 2009 7:55 am
Last Name: Hodge
Beautiful piece of artwork Bob. [:Y:] [clap]
Bill Hodge
PostPosted: Wed Apr 08, 2009 10:45 am
Sweet, Bob. That's the guitar I'm going to build.
(Well, different shape.)
But you continue to inspire, mate!
Thanks for posting,
PostPosted: Wed Apr 08, 2009 4:58 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Great looking fingerboard.Is that something you sell?
James
James W Bolan
Nashville Tennessee
PostPosted: Wed Apr 08, 2009 5:18 pm
Thanks Bill and Steve.
James - a fingerboard like that would be available through Tim Spittle, although I wouldn't recommmend it for an instrument that's going to get a lot of use. Blackwood isn't that hard.
http://www.australiantonewoods.com/atw/prod03.htm
This guitar is being kept by Dave, who builds with me, for his own personal use so it's not going to be heavily used and should hold up reasonably well.
Bob Connor
Geelong, Australia
Users browsing this forum: Glen H and 38 guests
