It is currently Tue Aug 05, 2025 1:08 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Wed Mar 11, 2009 8:31 am
Howard Klepper wrote:
You can anneal, harden, and temper with a torch, and make it work OK. But it will be pretty much impossible to do it as well as you can with a forge.
Sorry Howard heat treating with a propane or oxy-acetylene setup can give as good results if not better than a forge as you can differentially harden and temper to end up with a tougher blade this is unobtainable in a forge.
The most important steps in heat treating are thermo cycling this is bringing the article up to critical temperature (non magnetic) holding it there for a minute or too then quenching in oil or water depending on the steel this reduces the grain size in the metal, then temper like todd said until the colours run and I'd imagine a dark straw would be what your after as light straw can be a little chippy
Formerly JJH
PostPosted: Wed Mar 11, 2009 9:45 am
The most important steps in heat treating are thermo cycling this is bringing the article up to critical temperature (non magnetic) holding it there for a minute or too then quenching in oil or water depending on the steel this reduces the grain size in the metal, then temper like todd said until the colours run and I'd imagine a dark straw would be what your after as light straw can be a little chippy but it's all dependant on the steel.
Formerly JJH
PostPosted: Wed Mar 11, 2009 5:12 pm
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
CWLiu wrote:
These Narex chisels look almost identical to my Garret Wade set which is also made in Czech. I thought they work oaky.
I bought 2 sets of the 6-piece-in-box Narex chisels a few years back when they were on special for appx. $25. They are now $50 from Highland Hardware but if you buy the 4-piece set and add the other 2 separately it comes out to $35. You are spending $15 on a box that will get used once.
When I bought these, the cashier said these are made by the same manufacturer as the $72 Garrett Wade 6-piece set. They are decent chisels for the money but I have bought many 100 year old steel chisels off eBay that I use more often. They are still useful though - not a bad buy.
John Lewis
PostPosted: Wed Mar 11, 2009 9:08 pm
Last Name: Sterling
City: Ulster Park
State: New York
Zip/Postal Code: 12487
I have alot of chisels that I have collected over the years Maples, Japanese, plus alot of used ones that I have picked up. The odd things is the ones I reach for are some old socket type Stanley and Keencutter chisels.( Alot of this is how it feels in your hand balance plus the feel of the handle I like wood) They are similar to the Lie-Nielson. Many years ago I heard someone say when you buy a chisel or a plane you are buying a tool kit because of the work that goes into making it work right. I would try to pick up some used chisels that way you're not so annoyed when you have to put time into. I think you can tell if something is quality by looking at it. If the fit and finish is good the steel is probably good.
Mistakes are mandatory-learning from them is optional. http://www.opensourceluthiersupply.com
PostPosted: Wed Mar 11, 2009 11:15 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
John,
That extra wood box you used once, would you sell it to me?
Users browsing this forum: bftobin and 16 guests
