It is currently Tue Apr 29, 2025 8:25 pm
PostPosted: Sat Jan 22, 2005 11:46 am
This is a rosette I made using a fine slice of flamed maple Steve Roberson sent me, its going into the 12fret dread, also the top is Carpithian Spruce from Steve as well.
Thanks for lookin
PostPosted: Sat Jan 22, 2005 11:57 am
Nice lookin' !
PostPosted: Sat Jan 22, 2005 12:16 pm
Nice...
I like it when builders come up with something new for rosettes. And I love a big ole wide strip of abalone...
Good Job
-Paul-
-Paul-
Patriot Guitars
PostPosted: Sat Jan 22, 2005 12:57 pm
State: ON
Looks good!
I am about to try something similar only the wide strip in the middle will be wood and the thinner strips on the outside will be shell.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Sat Jan 22, 2005 1:17 pm
Nice rossette Lance. I like the Combo. How do you like that Carpatian spruce so far? Been meaning to get some.
PostPosted: Sat Jan 22, 2005 1:27 pm
Dead Gorgeous!
PostPosted: Sat Jan 22, 2005 1:57 pm
Looks fantastic Lance. Nice work as always. Just got some of that carpathian spruce in. Looks really nice. very stiff, good tap tone. Bobc38374.9156481481
PostPosted: Sat Jan 22, 2005 3:21 pm
Lance,
Nice! Looks really sweet.
One question, is it 3 diffrent pieces, wood, shell, wood, or is it one piece of wood with a channel for the shell?
Jeff
PostPosted: Sat Jan 22, 2005 3:36 pm
Thats a beauty Lance!!!
PostPosted: Sat Jan 22, 2005 11:12 pm
Saweet... nice job dewd.
Love the carpathian spruce, nice stuff indeed.
I am going to use it on my next guitar, I got some carp bracewood as well. I`ll let ya know what I think.
Matt
PostPosted: Sun Jan 23, 2005 12:49 am
Thanks Guys, here are a few images on how this rosette was made..
Start with a 3 piece Red Abalone heart inlay
Here its inlaid into a flamed maple blank, along with a b/w/b strip on either side, the deep channles are where it separates when I run it through my thickness sander.
The channels are as deep as the ablone is thick.
Here it is after having been ran through the sander, you can see how its come apart from the blank.
Finaly, its inlaid into a channel in the top, along with another b/w/b purling.
LanceK38375.3683101852
PostPosted: Sun Jan 23, 2005 1:39 am
I have to try that, it looks like fun!
PostPosted: Sun Jan 23, 2005 2:30 am
It looks wonderful! I don’t think I can hack it without a thickness sander though.
PostPosted: Sun Jan 23, 2005 2:31 am
Thanks Lance! Pictures explain things so quickly when you are trying to learn something.
Jeff
PostPosted: Sun Jan 23, 2005 3:52 am
Colby,
It's still easy without a thickness sander. All you have to do is route the channels a little deeper until they go through to cut it out. I like how simple the sander is, but you shouldn't have any problems the other way either.
PostPosted: Sun Jan 23, 2005 5:54 am
This is the same way I do my snakewood ones, I make an octagon with the snakewood and center on a piece of scrap and then route and cut out the piece before inlaying it into the top. I run it through the thickness sander to get it to release, you don't have to do that but it's easier to route these with a more solid base under them.
I'm now starting to use a vaccum jig to hold my rosettes so I don't need as big of a base and can but them free from that by just going deeper..
-Paul-Sprockett38375.580625
-Paul-
Patriot Guitars
PostPosted: Sun Jan 23, 2005 10:01 am
Look great Lance.
Sad to say, I got your maple back the other day cause I put the wrong address on the package. I'm truly sorry (no pun intended).
Well done again.
Rod
PostPosted: Sun Jan 23, 2005 10:15 am
No Prob Rod,
PostPosted: Sun Jan 23, 2005 10:21 am
Nice Job Lance. I never thought of doing that sander release thing. Very clever.
PostPosted: Sun Jan 23, 2005 12:09 pm
Why doesn't the sander throw the rosette across the room? After you sand away the remaining wood, what is holding the rosette in place or am I missing something?
PostPosted: Sun Jan 23, 2005 12:11 pm
the sander has pressure rollers that hold the whole thing down plus, I use my fingers to add pressure on the infeed and out feed.
PostPosted: Sun Jan 23, 2005 3:48 pm
[QUOTE=Mike Mahar] Why doesn't the sander throw the rosette across the room? After you sand away the remaining wood, what is holding the rosette in place or am I missing something?
I think that's a grand question...because, pressure rollers or no, if this were done in MY shop, that rosette would be imbedded in some wall, or crashing through a window. Lance has the touch.
And, he has one fine looking rosette!
Steve Steve Kinnaird38375.992662037
PostPosted: Mon Jan 24, 2005 3:10 am
Lance I think I have seen this before
PostPosted: Mon Jan 24, 2005 3:14 am
indeed! indeed!
Concept to reality!
PostPosted: Mon Jan 24, 2005 4:35 am
What is the specs on this? What size Ab are you useing, and how much maple are you leaving?
(Not planning on copying it exactly, but I like your dimensions.)
