It is currently Mon Aug 04, 2025 4:35 pm
PostPosted: Tue Feb 03, 2009 10:14 pm
In my never ending quest NOT to re-invent the wheel, I am wondering what information/opinions you folks could provide regarding how thin you can go on the back and sides (mahogany) on a steel string OM sized guitar. What happens from a sound standpoint?
Thanks, Peter
PostPosted: Tue Feb 03, 2009 10:43 pm
First name: David
Last Name: LaPlante
To put it simply, thinner is not better.
On an OM sized steel string I would optimally guage in these ranges:
.080" sides
.100"-110" top
.095-.105" back
you can vary these a bit depending on the cut and stiffness of the wood.
In general the thinner you go, the more you risk the loss of sustain and brightness resulting in an unpleasant overdriven and hollow tone.
PostPosted: Wed Feb 04, 2009 12:14 am
With stiff, hard, strong woods (not mahogany) you can go thinner. I've had good results going to .080-.085" on the back with ebony and some rosewoods. Bruce Sexauer usually goes thinner than that. But if you are new to building and using mahogany, stay with .095-.100" for your back and .080" sides. You are more likely to lose than to gain going thinner.
