It is currently Mon Aug 04, 2025 10:47 am
PostPosted: Wed Jan 28, 2009 12:13 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I am looking for specs on reverse kerf lining
my first attempt broke on the upper bout curve. It was,
.188 x 5/8, kerf was 1/4" apart & cut to a depth of.155
I'm thinking of putting the kerf about 3/16 apart
started with mahogany but want to use sitka on the top.
Mike McNerney,
Ottawa
looking for other builders in Ottawa?
Mike McNerney
PostPosted: Wed Jan 28, 2009 12:39 pm
Your lining size seems fine, about what mine is - but you can cut the kerfs deeper - how floppy is the lining prior to installing - it should flex a fair bit. Another thing I do is as I am about to install, soak the lining inside and out with some water (i spritz it). Let is soak for a minute or so, maybe even spritz some more. Then using a heat gun, as I am getting the lining into the guitars side, I hit the area needing to bend the most with the gun, pushing it into the side as it heats up and starts to flex. You will still get the odd break, but it works much better.
PostPosted: Wed Jan 28, 2009 3:20 pm
Here you go, Mike...
PostPosted: Wed Jan 28, 2009 5:15 pm
First name: paul
Last Name: harrell
City: Pittsboro
Don't have my measurements handy, but I leave the rib a good bit thicker than commercial reverse kerf lining (shallower kerfs). Then I bend them in my fox-style bender. Works great and makes for a very stiff rim set.
Peace, Paul
Users browsing this forum: JimWomack and 38 guests
