It is currently Mon Aug 04, 2025 5:39 pm
 Post subject: cocobolo bridge glue-up
PostPosted: Tue Jan 27, 2009 1:44 pm
How would you prepare a coco bridge for glue -up? Naptha&scrape?
PostPosted: Tue Jan 27, 2009 1:57 pm
Disclaimer: I have never glued a coco bridge before.....
Mark my friend from what I have read here I would go with a good scrape. In previous threads I got the impression that using solvents like Naptha might actually bring more oil to the gluing surface.
PostPosted: Tue Jan 27, 2009 2:06 pm
I've heard the same thing about naptha bringing the oils up.I had someone tell me to use acetone on rosewood boards once.But never tried it.
PostPosted: Tue Jan 27, 2009 2:47 pm
Mark Geiger's recommendation for all gluing of cocobolo was: wipe with naptha, glue as soon as the naptha flashes. That's for gluing with titebond.
I glued a cocobolo bridge to redwood using that method. I really wiped thoroughly with the naptha until I got rid of any residual color bleeding. I also gave the surface a light scraping prior to wiping with naptha. It seems to have worked (knock wood).
PostPosted: Tue Jan 27, 2009 3:12 pm
I've used many cocobolo bridges and a fresh surface works fine for me. Never used a solvent.
http://www.chassonguitars.com
PostPosted: Tue Jan 27, 2009 3:35 pm
Kent,
With your experience, can you characterize the difference in sound between a cocobolo bridge and a IRW or Ebony one? I am contemplating a cocobolo bridge on an OM that is at Joe White's for finishing and would like to know.
PostPosted: Tue Jan 27, 2009 5:11 pm
SteveCourtright wrote:
Kent,
It's pretty low damping and heavy is what I can say objectively. Beyond that, it really depends on so many other things that I'm reluctant to make broad generalizations. As far as my guitars go, I build pretty light tops and I find that they sound best with relatively heavier bridges. More disciplined, more focused, sometimes less string noise. But that's just me.
One way to get an idea about mass on your own guitars is to stick some washers or coins on your EIR bridge with putty or double stick tape.
PostPosted: Tue Jan 27, 2009 5:20 pm
I've done fine with an acetone wipe on cocobolo. More recently I've just been using a fresh surface, sanded or scraped within 5 minutes of gluing; no problems with adhesion.
PostPosted: Tue Jan 27, 2009 7:08 pm
First name: Heath
Last Name: Blair
City: Visalia
great tip! thanks!
sweat the small stuff.
Users browsing this forum: ballbanjos, Bing [Bot] and 33 guests
