It is currently Mon Aug 04, 2025 11:05 am
PostPosted: Tue Jan 06, 2009 9:09 am
Last Name: O'Melia
City: Huntsville
State: Alabama
What do you use? Side material? Mahogony? Birch? And, generally, how thick?
PostPosted: Tue Jan 06, 2009 9:22 am
Laminated sugar maple with cross-grain Brazilian RW, Honduran RW, cocobolo or bloodwood. Stack is .090"/.095" thick.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Tue Jan 06, 2009 9:49 am
Mike my friend I use Honduran Rosewood or BRW.
PostPosted: Tue Jan 06, 2009 9:55 am
EIrw back cutoffs from the Larrivee factory !!! Local wood shop had a huge box of them - cheap too - already thicknessed to 90 thou ... quick scrape and they are ready to go.
PostPosted: Tue Jan 06, 2009 10:52 am
I have used maple, osage, brazilian and also african blackwood a few times but now I prefer a thin strip of pernambuco(.08-.09 thick and 3/4 wide) to anchor the pins over a larger spruce patch (.04 app.) glued with the grain going the same direction as the top.
Burton
Brookline, MA.
PostPosted: Tue Jan 06, 2009 10:54 am
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
Any thoughts about Mad RW for the bridge plate?
Thx!
Glenn
PostPosted: Tue Jan 06, 2009 10:59 am
I think anything fairly hard that doesn't crack when flexed across its length should make a fine bridge plate. Mad RW should be an excellent choice!
Burton
Brookline, MA.
PostPosted: Tue Jan 06, 2009 12:03 pm
First name: Tracy
Last Name: Leveque
State: CO
I've recently switched to Padauk because of a few guitars I've played that are basically Martin braced seemed to have a more open woody tone to my ear. Not sure it is true, but the wood is hard and dense enough for string wear. Also, I learned that Goodall uses this too, and I like the tone of his guitars. Mine are slightly over 2mm thick and quarter sawn.
PostPosted: Tue Jan 06, 2009 2:07 pm
.09 thick riff cut suger maple :D
PostPosted: Tue Jan 06, 2009 2:46 pm
Am currently partial to pau rosa. Usually a two piece laminate with grain running in a shallow X pattern--each side about 20ยบ off from perpendicular to the top grain, and the outside layer running opposite to the bridge pin line (which I angle with the saddle), so the pin line is well off from parallel to the outer grain line.
I also use other woods: osage orange, EIR, BR.
No reason not to use Mad rose.
Rift sawn is best. Since I use back cutoffs and orphan sides, usually it's more like quarter-to-rift.
PostPosted: Tue Jan 06, 2009 2:53 pm
Same here.
Alain Moisan
(Now building just for fun!)
PostPosted: Wed Jan 07, 2009 3:46 pm
Why riff instead of slightly off-quarter? idunno
PostPosted: Wed Jan 07, 2009 3:54 pm
Rift cut, with the annual ring lines at 45 degrees to the surface, has the lowest cross grain stiiffness, so that it can flex with the top, and the greatest resistance to splitting.
I used osage for several years as it is hard and resists splitting, but then I found something even better: persimmon. The biggest problem with osage is that it's ring-porous, so that a string ball could end up on a soft part of the grain and chew righht through. Persimmon is diffuse porous, very tight grained, and hard, so that's not an issue. It's also the hardest wood to split I've run into.
Users browsing this forum: JimWomack, Ken Lewis and 47 guests
