It is currently Sat Aug 02, 2025 12:27 pm
 Post subject: making bindings
PostPosted: Sun Oct 26, 2008 4:59 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I want to make my bindings & add a w/b strip on the edge and then bend on the pipe. Can this be done & what kind of glue is recomended that will hold up to the bending procedure.
Mike McNerney
Mike McNerney
 Post subject: Re: making bindings
PostPosted: Sun Oct 26, 2008 6:17 pm
Titebond usually works fine. Tape two pieces of binding together, purfling to purfling, before bending and that will help hold the purflings in place while bending. Just don't soak the strips or overheat them and the glue will hold.
http://www.chassonguitars.com
PostPosted: Sun Oct 26, 2008 7:00 pm
Heres how I glue up BWB to my rosewood bindings. The clamps are lining clamps from Blues Creek Guitars.
PostPosted: Sun Oct 26, 2008 8:01 pm
I like to use cyano to glue purflings to bindings prior to bending. Cyano holds up really well to moisture and heat. I have used Titebond but it tends to loosen a bit under heat and sometimes leaves a white line.
I made a jig lined with Teflon strips to hold the purfing in place against the bindings. Once I have it where I want it, I run a bead of thin cyano along the joint. The Teflon prevents the binding from being glued to the jig.
Mark
PostPosted: Mon Oct 27, 2008 12:46 pm
when i make laminate bindings i make a binding billet that its 7-7 1/2 mm thick and 1"+ wide x 32"+ long.
i then laminate normal 0.6mm veneer to the bottom of this in whatever layers i want (black/white/black etc) with titebond three.
i find this does not delaminate during bending like normal titebond as its water resistant.
i then cut the resulting laminate into 2.5mm strips on my small bandsaw.
i then run then through the drum sander to take off the saw marks from each side until they are 2mm thick.
i will often hold them all together at this stage and run the top through the drum sander to take the finished bindings to about 6.5-7mm .
i have never found a satisfactory way of gluing purflings to binding strips but titebond 3 and clothes pegs is the best i have found so far then i like to tidy up lightly with drum sander before bending and gluing.
Joel.
PostPosted: Mon Oct 27, 2008 9:03 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Don't forget fiber board! Cool stuff.
PostPosted: Tue Oct 28, 2008 8:58 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
thanks all, Joel, your method is the way i have been thinking, of doing it
mike mcnerney
Mike McNerney
PostPosted: Tue Oct 28, 2008 10:39 am
Mark
This is almost the exact method I use. It's quick and easy and I have yet to have a problem with delamination during bending.
Users browsing this forum: CarlD, DanSavage and 34 guests
