It is currently Sat Aug 02, 2025 12:59 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
 Post subject: Re: Shop made jigs
PostPosted: Wed Oct 01, 2008 5:30 pm
Mini table saw for cutting fish paper or veneer purfling strips. It started life as a harbor freight chop saw. (~$25 if I remember correctly.) Friendly Plastic holds the melamine table in place.
PostPosted: Mon Oct 13, 2008 10:39 am
Hey Bob- How is the blade on that unit, does it cut smoothly? What size is the blade? I recently bought the mini table saw but the blade is less than desirable...
Jim
PostPosted: Mon Oct 13, 2008 11:37 am
I have one of those I have used to precut purfling miters for complex rosettes. The blade cuts fairly smooth as long as you keep the resin cleaned off. It is a toy construction wise, but one that can be worked with
PostPosted: Mon Oct 13, 2008 4:07 pm
Jim, here's a link http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=42805
It's ~.020 thick.
I've only used it to rip fish paper and it does a decent job. But, if you need something that leaves a smooth finish I don't think this is what you're searching for.
PostPosted: Tue Oct 14, 2008 9:11 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Really? I was just sitting thinking about how to cut fish paper (fiber paper). This really works?
Thats a hoot!
PostPosted: Wed Oct 15, 2008 6:08 am
Here's on I recently finished.
Inspiration is pretty obvious, but being in the UK I couldn't justify the expense on the real thing, not once shipping and customs were factored in. I've fretted one neck so far, and it works very well. The fret caul holder arbour is glass filled nylon, and the neck caul is a teak offcut, from a piece I rescued from a skip. The jaw which supports the neck caul, and allows it to slide back and forwards is cut from a door-closer swing arm, another piece destined for the bin, before I liberated it.
The donor tool came from Screwfix, as part of a 3 piece set, for all of £8.99. The flat clamp, intended for clamping sheets together for welding is very usefull for holding nuts and saddles for shaping on the disc sander.
These users thanked the author Setch for the post: Kbore (Tue May 06, 2025 11:32 pm)
PostPosted: Thu Oct 16, 2008 9:28 pm
Thats a hoot!
yup, for 010, 020 and 030. although it wasn't too happy about the 030.
PostPosted: Fri Oct 17, 2008 5:45 pm
G'day Bob,
' Shop made jigs ' is always an interesting thread . Thanks to all who have posted .
These are just a few I've come up with:
Here's my version of the " Robo Sander ".Made the bottom " Robo " part out of Tas. Myrtle ( not Tiger :D ). Gives a bigger table than the Stewmac ,and living in Australia (postage ),saved a small fortune , although I did buy their slide vise pictured.
The drum is wood . which I have trued up ( I removed it's original soft covering ,,,,don't enjoy rounded over corners and edges etc. ). It has a very clever and convenient sandpaper clamping system.
I don't often use the ' Robo ' system , but the drum sander gets a good work out. The drum can be lowered into a hole in the bench top when the Myrtle plate is removed.
This is a pic. of my Saftey Planer set up. I find I don't use all that much either , but is handy for reducing down the back of headstocks , thicknessing bridge blanks ,headplates etc . .I thinned down those Tas. Myrtle slats to give just the right amount of hold down flex , although the bearings are adjustable foe height anyways . They can be turned to suit your direction of cut also .
I made this quite some time ago and is my favorite so far . I've posted pictures of it before , so apologies to those who are probably sick of seeing it !
Made from scrap Aluminium ( Aussie spelling :D ), Brass , Bronze, Copper and Steel. It's in metric . The needle bearing spindle is from a record player turntable . The upper bout of the little guitar becomes the cam , while the lower bout acts as a counterweight . There is also a counter/counter weight on the indicator arm. The lower anvil ( below the measuring probe ) is radiused at it's base and sits in a bronze bushed hole and can move around quite freely This radius is of the same radial tangent as the probe's tip giving a consistant reading no matter what angle the wood is presented to the jig , whereas A conventional rounded domed anvil can give a higher reading unless presented at the exact 90 degree angle to the probe
Craig Lawrence
CRAIG LAWRENCE of AUSTRALIA
PostPosted: Fri Oct 17, 2008 5:57 pm
I have many more ! . Seems you can never have enough jigs ! :roll:
Cheers to all !
Craig Lawrence
Users browsing this forum: dofthesea and 31 guests
cron
