It is currently Sat Aug 02, 2025 9:47 pm
 Post subject: Parlor bracing
PostPosted: Mon Oct 06, 2008 8:52 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Okay, new guy here again. I've got my top thicknessed for my parlor, I've go the bracing plans from LMI...any thoughts on scalloping the braces for a parlor? Lighter than usual because of the size? Any opinions would be much appreciated.
Thanks in advance
 Post subject: Re: Parlor bracing
PostPosted: Tue Oct 07, 2008 1:53 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I agree with Todd !
How thick is your top?
Mike Collins
PostPosted: Thu Oct 09, 2008 8:14 am
Last Name: Denvir
City: Baltimore
State: ON
About 1/8" after hand planing
PostPosted: Thu Oct 09, 2008 8:46 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Now at about .125, start feeling and listening to the wood and stop when it feels right. Can't tell you what the feel of that particular board should be, but you will feel it in stiffness, seperation etc. Since first and not sure maybe, probably not lower than .100 or so. Keep it light inside the box. Might consider non scallop bracing (what is I quess noted as parabolic) Learning the wood and feel is part of the learning process of building.
PostPosted: Thu Oct 09, 2008 2:33 pm
Last Name: Livermore
State: Minnesota
Good luck with your Parlor.
One more tip on the Antes plan. Quite a few people, including myself have been confounded by the one page plan that has one drawing for both the top and bottom of the top. So if you follow it as planned, (not flipped) the lower legs end up on the wrong side.
Just something to think about.
Incidentally, I left it reversed and it sounds just fine. I did use 1/4" bracing and an extra long bridge so it would extend over the X. If you want to see it or hear it, I did post it back in August on this forum.
PostPosted: Thu Oct 09, 2008 8:11 pm
Last Name: Denvir
City: Baltimore
State: ON
ToddStock wrote:
I used a Lutz top at .105 (thinned to .100 or so at the edges) with 1/4" x 1/2" X.
Forgive my ignorance, but the X means...? High point of scalloped brace?
PostPosted: Thu Oct 09, 2008 9:27 pm
Steve,
I believe he's referring to the height at the intersection point of the X-brace
(not including the "cap" that most folks add).
Eric
PostPosted: Fri Oct 10, 2008 7:54 pm
Last Name: Denvir
City: Baltimore
State: ON
Thanks everyone, I'm getting there. It's not happening fast, but I am getting there :-)
Users browsing this forum: bobgramann and 44 guests
