It is currently Sat Aug 02, 2025 10:29 am
 Post subject: neck/head joint
PostPosted: Sun Oct 05, 2008 3:29 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
When I was in barcelona last year I stumbled on a flamenco luthiers shop & he had a head joint that was some kind of sliding mortise & tenon at the 13 de. angle & it may have been dovetailed too. I tried, from memory, to mock one up yesterday with a dovetail, but not really sure if I got it the same way he did?
It sure is strong however. It will be very timeconsuming. Are there any photos or designs out there in cyberspace?
mike mcnerney
Mike McNerney
 Post subject: Re: neck/head joint
PostPosted: Sun Oct 05, 2008 3:53 am
Your talking about a V-joint. A lot of classical builders use it. Joshua French did a superb tutorial on it for the forum some time ago, it can be found here:
http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=10511&hilit=+joint+jfrench
They take a bit of practicing to get right but are an elegant form of joint.
PostPosted: Sun Oct 05, 2008 8:18 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
No that is not what I saw. It is more the way I descibed it. I'm going to try another one today & maybe I'll learn how to post a picture.
mm
Mike McNerney
PostPosted: Sun Oct 05, 2008 6:02 pm
I saw a discussion somewhere about using a finger-joint on the head/neck joint. Could that be what you are talking about?
PostPosted: Tue Oct 07, 2008 11:58 am
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
Here's a pic from frets.com of the old Martin joint.
- Louis Freilicher
PostPosted: Tue Oct 07, 2008 12:44 pm
That modified bridle joint is also called by one classical maker a 'Fussen V-joint'. It's what Hauser used. It's actually a fairly easy one to make and fit if you're good with a table saw. Julius Borges uses it on his Martin copies, and that's where I first saw one going together.
PostPosted: Wed Oct 08, 2008 12:56 pm
Alan,
Do you know of an instructional video or any other type of tutorial on how to execute this joint?
Jimmy Caldwell
PostPosted: Fri Oct 10, 2008 6:14 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
OK here is a sample of what I remember. I'm calling it an open mortise & tenon. I cut the mortise on the TS with a dado 5/8" & the tenon on the TS with a sliding fixture set at 13 de. It is incredibly strong, & offers much more glue surface than the scarf joint.
I hope folks will give me their opinion. Does it affect the ascetics of the final shaping at the back side?
Mike McNerney
Mike McNerney
