It is currently Fri Aug 01, 2025 6:46 pm
PostPosted: Tue Sep 30, 2008 6:39 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I read some stuff about planing and that with thinner wood and figured wood it's best to thickness sand. However all the thickness sanders I have seen cost a LOT of money, so is it possible to thickness sand by hand or using a portable belt sander? Or do you just plane it to the right thickness then finish by sanding?
Typhoon Guitars
PostPosted: Tue Sep 30, 2008 7:16 pm
Plane close to thickness and finish with a card scraper and scraper plane.
you will get a much a better finish on the wood than with sanding.
even when i thickness sand i still only sand close to thickness and take it to the final thicknes with a scraper plane,
Joel.
PostPosted: Wed Oct 01, 2008 8:32 am
There's also the Wagner Saf-T-Planer for use in a drill press, as long as the drill press has a large enough swing.
http://www.stewmac.com/shop/Tools/Planes/Wagner_Safe-T-Planer.html
http://www.patfosterguitars.com/harvest2/pages/page_3.html
Less of a learning curve than a hand plane and scraper, but not as much fun.
PostPosted: Wed Oct 01, 2008 8:38 am
The problem with hand sanding is in maintaining a consist thickness. Hand sanding even with a RO will leave you with spots that are lower and spots that are higher. Hand planning, a Wagner Safety Planer or even a shop made disc sander will be many times more consistent than hand sanding.
PostPosted: Wed Oct 01, 2008 8:45 am
I have ran in to the problem that Michael has mentioned, especially in Cedar, where the wood is so much softer than the rosette and binding edges.
Now after the top is on and guitar is bound and scraped flush, I do my final sanding with a 4X8 oak sanding block. This was a tip I got from Mark Blanchard.
This really helps make the top nice and dip free!
PostPosted: Wed Oct 01, 2008 9:05 am
Many of us have made drum sanders for this. My unit, which was built largely of 2"x4"s, plywood and particle board is accurate to 0.1 mm on a good day. It is hand fed and needs tweaking from time to time to maintain the accuracy, so you need a steady hand, but the thing works. And you can’t beat the price! I hand plane backs and sides close to final thickness and then go to the sander. Easy woods I plane the closest (sometimes all the way), figured or otherwise difficult to plane woods start out thicker as a tear out when you get close to done can ruin a piece. Tops I usually just hand plane as I like to taper their thickness and that is easy to do with the plane, besides softwoods are such a joy to plane.
A shop made disc sander? How would one look, and how would you use it for this?
PostPosted: Wed Oct 01, 2008 9:41 am
This one is not homemade, but purchased from Specialty Tuners web site (think Gilbert Tuners). It works very well for thicknessing small stuff, or will also even out sides, backs or tops, depending on your DP size. Mine is only a 14", but that gives me about a 18" reach overall with the 5" disk, if you remove the fence for the last passes. Here, I'm doing little stuff for a rosette tile.
PostPosted: Wed Oct 01, 2008 3:07 pm
Since you mentioned Timesavers in your message, you may not know that there are lots of relatively inexpensive thickness sanders that cost far less than a Timesaver, which is a large industrial machine. You should investigate the Performax, Delta, Grizzly and other companies - they all make sanders for a fraction of the cost of a Timesaver that will do an adequate (but slower) job for you.
Brook
PostPosted: Thu Oct 02, 2008 4:33 am
Lance Kragenbrink wrote:
I do my final sanding with a 4X8 oak sanding block. This really helps make the top nice and dip free!
I've been doing this for years from doing autobody work! Really works well, even on large contours. The important thing is to work the radius on a bias to centerline in a cross hatch fashion.
I wanted to say also one of the most sensitive tools available to find dips or other uneveness is one's own hands. It's amazing what one can feel just by running your hand over a surface. Things you can't even see easily, pop right out to the hand.
PostPosted: Thu Oct 02, 2008 8:50 am
Before i got my delta drum sander,i used a marble threshold with 4" self stick sandpaper rolls .And it got everything perfectly flat.I still us them for laminating solid bodies.It sort of works like a granite plate,except you hold this plate in your hand to sand flat.You can buy these thresholds at lowes for around 8 bucks.They are the marble like plates that are installed across the doorway on the floor into a bathroom .They are perfectly flat,and make a great sanding fixture.
Users browsing this forum: JasonMoe and 24 guests
