It is currently Tue Jul 29, 2025 2:02 pm
 Post subject: rookie question
PostPosted: Wed Aug 20, 2008 12:55 am
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
So I'm working on profiling the sides by sanding in the sanding dish. My question is, as you sand the rim, specifically the back, and it begins to assume the profile imparted by the radius dish, in order to fit the back to it, wont it need to be flexed longitudinally somewhat? The reason I ask is that though the braces are radiused, there is nothing to maintain the radius longitudinally. Is this correct?
I can see if the X braces for the top are radiused that they will be able to maintain the neck to heel radius but not having this on the back doesnt allow for that. Am I missing something here? idunno
Darrin
 Post subject: Re: rookie question
PostPosted: Wed Aug 20, 2008 6:19 am
Yes, it should flex into positon easily.
PostPosted: Wed Aug 20, 2008 6:21 am
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
When you glue the back to the rim, it will creat the radius the long direction automatically. So basically, you are creating the radius one direction when you glue on the braces and the other direction when you glue the back to the rims.
John Ressler
PostPosted: Wed Aug 20, 2008 7:03 am
Ive started using a cross brace on lower bouts of my backs.
PostPosted: Wed Aug 20, 2008 7:42 am
Yep good observation Darrin buddy.
Some food for thought - An X-braced back, at least where the X-brace is say the lower bout, needs to be flexed less or not at all to fit where ladder braced backs do need to be flexed more. I am not advocating X-braced backs just using this example to illustrate your question.
PostPosted: Wed Aug 20, 2008 11:08 am
First name: Darrin
Last Name: Oilar
City: Cottonwood
OK...cool. I just wanted to make sure I wasnt missing something. I've already made serveral ut-ohs along the way, with more to come. Thanks guys.
Users browsing this forum: Tim Cross and 12 guests
