It is currently Mon Jul 28, 2025 9:44 am
 Post subject: Vacuum clamp kits?
PostPosted: Mon Aug 04, 2008 12:47 am
First name: Zachary
Last Name: Bulacan
City: Anchorage
State: Alaska
Does anyone make or use a hand operated vacuum clamp setup? is it even worth using? This will be used with soprano ukes so small stuff only
Zac
Anchorage Alaska
Finshed my 1st! See #1 here
 Post subject: Re: Vacuum clamp kits?
PostPosted: Mon Aug 04, 2008 1:34 am
First name: Zachary
Last Name: Bulacan
City: Anchorage
State: Alaska
fmorelli wrote:
Never heard of anyone doing it. Why? What are you trying to do??
Filippo
well thinking of a way to clamp a bridge if I do soundholes in the upper bout and clamping radiused braces with out using a gobar deck (no space)
Zac
Anchorage Alaska
PostPosted: Mon Aug 04, 2008 2:50 am
Dont know if its applicable but a skateboard company called Roarockit make a little hand pump operated vacuum clamping kit. Looks like one of those little wine bottle pumps. I have seen photos somewhere of someone using something similiar for a guitar.
Warren.
PostPosted: Mon Aug 04, 2008 2:27 pm
i don't think it is very practicable, unless you have a bionic arm.
PostPosted: Tue Aug 05, 2008 4:12 pm
Zac,
I’m not sure of how much vacuum is required to pull down a bag the size of a ukulele bridge. It needs to have enough pull to create good glue joint. Maybe others with experience will chime in. Harbor freight has some small vacuum pumps that could very well be adapted for use. I thought that they may be cheap enough to give it a try. My wife has several very large vacuum bags to hold materials and is sucked down with a vacuum cleaner. One of these bags has a leak so I will make mine using that material. My plans are for a wooden housing, inner tube for a seal, and the vinyl (?) from the bag. Harbor Freight has two vacuum pumps that pull down to 28.3 inches of mercury for $12.99 or $16.99. Well there products may not always of the highest quality but they are cheap enough that you can toss them if they don’t meet your needs.
In the past, I have built a couple of very large vacuum machines used for plastics. These machines normally used a 2’ X 4” sheet of plastic that was heated in the machine and then pulled down over in house molds. Some of these had a pretty deep draw which really took some vacuum. I believe we used an 80 gallon tank and twin cylinder pump with the connections reversed so that it created vacuum instead of air pressure. The gauge was changed out to read vacuum. I sure made a lot of motorcycle fenders and parts with those machines. My guess is that you should be able to reverse the pump on any air compressor that you can do it on.
Good Luck
Philip
aka konacat
PostPosted: Wed Aug 06, 2008 1:29 am
First name: Zachary
Last Name: Bulacan
City: Anchorage
State: Alaska
Thanks Philip I was thinking about going with out a gobar deck and the possibility in the future of upper bout sound holes. I think what I will do is go for the wedging gantry that I saw in my classical guitar building book no over head like a go bar deck and easy and cheap to build and shelve the upper bout puka idea for now.
Zac
Anchorage Alaska
Users browsing this forum: Darrel Friesen, rbuddy and 16 guests
