It is currently Mon Jul 28, 2025 9:44 am
PostPosted: Sun Jul 27, 2008 3:08 pm
First name: Heath
Last Name: Blair
City: Visalia
im building a williams binding jig with the dave white modification. ive never worked with lexan before. im curious if i need to pre tap the holes in the lexan sub base to hold it to the small lazy susan? or can i just pre drill them and screw directly into the hole? i dont want to split the lexan. im not even sure how easy that would be. any advice would be appreciated.
sweat the small stuff.
PostPosted: Sun Jul 27, 2008 3:30 pm
Always tap!
Drill at very slow speed use a small amount of light cutting oil and light pressure. I usually squirt a small amount of oil on my finger and just rub it on the fluted sides of the drill, to avoid a mess, you don't need much. You'll get a very clean hole, then tap normal. Lexan/polycarbonate likes to melt if drilled to fast.
PostPosted: Sun Jul 27, 2008 4:59 pm
If you grind just the slightest flat on the front of each drill flute, so that there is a vertical face scraping the plex, rather than a sharp angled lip "scooping" the hole, you'll have no tendency for the bit to self-feed in the plastic, and the breakout through the other side won't be so abrupt and destructive.
I would tap the hole, and I would drill the tapping hole a bit oversize of the recommended, since the tap will try to exert a bit of a wedging effect as it cuts. Just don't torque way down when you run the bolt in.
Dan
Dan
http://www.acme-archtops.com
PostPosted: Sun Jul 27, 2008 7:43 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Always tap lexan and most plastics. If you don't, you will create high compressive
stresses around the screw holes, and cracks will often develop from these stresses,
sometimes a long time after the screw is inserted.
Gene
PostPosted: Sun Jul 27, 2008 7:49 pm
Last Name: Garrish
Always tap. If you can get your hands on one, use a machine (spiral) tap rather than a hand tap. They don't auto-align, so you need to eye up your hole to make sure it's straight, but they put a whole lot less stress on the material. I do all my tapping, by hand or not, with machine taps now.
Bob Garrish
PostPosted: Mon Jul 28, 2008 12:13 am
First name: Heath
Last Name: Blair
City: Visalia
so let me get this straight, what you are saying is that i should always tap? :D well, thanks for that advice guys. i guess ill have to borrow some taps from my dad. hes the machinist. not sure how i ended up in working wood. :D
PostPosted: Mon Jul 28, 2008 12:09 pm
Bu, only tap if you really think it will be fulfilling! :D
Users browsing this forum: Darrel Friesen, rbuddy and 16 guests
