It is currently Mon Jul 28, 2025 1:39 am
PostPosted: Tue Jul 01, 2008 7:31 pm
Hi
I am fixing a friends 12 string. It is an old Yamaha dread 12 string with a slotted headstock.
Someone in the past put mini solid headstock tuners in it. They really don't work well. The hole for the string of course at the top of the post so it is too far in the middle of the headstock.
What I need are MINI slotted headstock tuners for steel string. I cannot seem to find them???
Do they exist???
Help is appreciated
PostPosted: Tue Jul 01, 2008 9:41 pm
Todd
This guitar has tuners that are just short of 1" center to center.SM doesn't show anything on their website
PostPosted: Wed Jul 02, 2008 1:35 am
You can cut the plates on individual 18/1 Grover Sta-tites for slot heads. Iirc, the mounting screw holes in the plates end up spaced just over 1" apart if you butt them using half of an original hole from each plate as in these photos. But you could go tighter and drill new holes for the mounting screws. Don't space them so close that the buttons can bump.
PostPosted: Wed Jul 02, 2008 11:57 am
Thanks Howard and Todd
SM didn't have the specs on the tuners yet
Andy
