It is currently Sun Jul 27, 2025 2:24 pm
PostPosted: Mon Jun 23, 2008 1:46 am
Drawing out my bracing pattern I noticed the back half of the bridge wings will fall between the X brace. The front will of course be over it and some outside of it. I'm using a typical 'forward shifted' Martin pattern but a regular belly bridge instead of the long through slotted(I think they're called that).
So is this:
1) Perfectly Fine
2) Ok but not ideal
3) Recipe for disaster
Thanks for playing, Jeremy
Jeremy Douglas
PostPosted: Mon Jun 23, 2008 6:07 am
1) Perfectly fine! :D
Not all bridge designs will have the entire bridge wings over the X-brace. You just want some of, more is better of course but you also don't want or need a 1' wide bridge.
PostPosted: Mon Jun 23, 2008 9:37 am
Thanks Hesh
bliss
Jeremy Douglas
PostPosted: Mon Jun 23, 2008 10:58 am
I will say this. The more you have the wings overlapping the x brace IE the closer to center mass of the bridge this intersection is the better job the x brace does in supporting the bridge against inward rotation. Which is the reason we want the bridge wings to overlap in the first place. there is a balance. Too close to center mass and you dampen the energy transmission. I like near half the wing length to overlap but I have a some what wide bridge design wit fairly thin wings.
I designed my bridge to carry a fairly inclusive variety of x brace spreads. I would never design the x brace spread to work to a narrow existing bridge design..
PostPosted: Mon Jun 23, 2008 2:36 pm
Thanks Michael.
Actually I looked at one of those light bulb in the guitar pics from a 30's D-18 and the bridge intersects the X in the exact same way as what I ended up with. So I'm good.
Jeremy Douglas
PostPosted: Mon Jun 23, 2008 2:45 pm
jeremy3220 wrote:
Thanks Michael.
You probably are. But you might want to check with some vintage guitar repair and restore techs to see how many of those vintage D-18 guitars have needed work due to bridge belling. I personal have seen a couple but I am not the person to ask. Frank Ford would be a great resource.
I do not doubt you are OK but if truly inquisitive to find the best situation, just saying just because a vintage D-18 has this much overlap in of its self would not be the end of my investigation.
Users browsing this forum: Chris Pile, Michaeldc and 19 guests
