It is currently Sun Jul 27, 2025 8:08 pm
 Post subject: Bent or laminated braces
PostPosted: Sun Jun 15, 2008 11:20 pm
First name: Brett
Last Name: Faust
City: Puyallup
Zip/Postal Code: 98373
Does any OLF member have any experience with steam bent or laminated and bent braces?
Any thoughts welcome. [:Y:]
Thanks ,Brett
How long is that in luthyears?
PostPosted: Mon Jun 16, 2008 3:43 am
First name: Kirby
idunno
Any examples?
I guess you could think of bent linings as bracing?
"It's a Tone Faerie thing"
PostPosted: Mon Jun 16, 2008 5:04 am
Didn't Hauser bend the brace next to the sound hole???
PostPosted: Mon Jun 16, 2008 6:53 am
Location: Between Bordeaux and the Atlantic. S.W.France
I'm sure Mark Swanson has used laminated braces, building up the laminations in situ with the back (or front) in the radius dish. I assume that this is what you mean: instead of cutting the brace to a curve to match front or back radius, laminating or bending it to match that curve.
PostPosted: Mon Jun 16, 2008 10:03 pm
First name: Brett
Last Name: Faust
City: Puyallup
Actually ,what I meant was a bend like an s or u or any kind of squiggle.
Not an arc to conform to a radiused top ,but curved sections instead of many small straight sections.
More a curve to make the braces in fewer pieces with taller and/or wider sections to voice the top.
Thanks for the input. :D
PostPosted: Mon Jun 16, 2008 10:28 pm
Gary Southwell is a classic maker who uses bent bracing on his modern classic guitars
http://www.southwellguitars.co.uk/aseri ... ruct.shtml
PostPosted: Mon Jun 16, 2008 10:30 pm
First name: Greg
Last Name: Harrington
I now see this is not what you mean. This is a laminated bracing which conforms to the radius produced by the radius work dish.
Greg
PostPosted: Tue Jun 17, 2008 12:09 am
Don't know if he will tune in, but Grant Goltz has a very interesting bracing system in his steel strings. He has this semi circular laminated brace which sweeps around the rear of a unique bridge plate which links a series of fingers together to drive the top like a diaphragm, very clever stuff and worth a search either here or over at luthiersforum.com.
PostPosted: Tue Jun 17, 2008 12:43 am
Here ya go:
http://www.luthiersforum.com/forum/viewtopic.php?f=10102&t=4278&st=0&sk=t&sd=a&start=0
PostPosted: Tue Jun 17, 2008 8:04 am
First name: Jim Howell
Kim--
Thanks for the link to the old post with Grant. It was before my time here and I've foiund it facinating.
Dennis--
How did your bracing experiment pan out? Are you using it, a variation on Grant's or back to a variation of the Martin 'X'?
Jim Howell
Charlotte, NC
