It is currently Sun Jul 27, 2025 11:07 am
PostPosted: Fri Jun 13, 2008 8:31 am
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
I wish I could say I was building a violin like Colin, but I am just installing violin tuners on a dulcimer and am wondering what is the proper method for final fitting of the tuners for a perfect fit and to keep them from slipping?
John Ressler
PostPosted: Fri Jun 13, 2008 8:37 am
No real way round it but a proper dimension tapered violin reamer. You could try (in some scrap first) sticking some strips of sandpaper to a spare peg and using that to ream the hole. A local violin maker might do the job for you cheaply as a one-off, but you will probably find that a reamer will be just as cheap.
PostPosted: Fri Jun 13, 2008 8:39 am
You'll need a reamer.
Suprisingly, they're called violin peg reamers! :) and are available at the big luthier supply houses.
Paired up with the reamer, there's also a peg-shaver (like a big pencil sharpener) which will cut exactly the same taper on to the peg as the reamer leaves in the hole. You may not need this though, as some pegs come pre-tapered to dimension.
PostPosted: Fri Jun 13, 2008 10:05 am
Last Name: Ressler
City: Sandwich
State: IL
I have the reamer and peg shaver - it looks like I have a decent fit - just wondering if there is any fine tuning that needs to be done beyond that. Or is that it and I'm trying to make it more difficult than it is.
John Ressler
PostPosted: Fri Jun 13, 2008 11:23 am
You can use a little peg paste on them if you like, it's cheap enough to try it.
PostPosted: Fri Jun 13, 2008 12:48 pm
Last Name: Ressler
City: Sandwich
State: IL
OK - thanks for the help
By the way Colin - that is a great looking violin - beautiful work.
John Ressler
Users browsing this forum: Facebook [Bot] and 22 guests
cron
